I've quick time 7 installed and I use TMPEG 2.5 but if i convert .mov file to mpg file i dont have the audio, do you have a solution? Thanks.
tmpgenc has always had problem with audio in mov. I would try convert with something else like convertxtodvd if you are gonna make a dvd. or https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=MOV+to&dvda...+or+List+tools
I use directly convert Xto DVD but nothing, no audio!!! Help me pelaseOriginally Posted by Baldrick
Converting .dv and .mov Mac file to MPEG-2 No Audio
By RL in forum ffmpegX general discussionReplies: 3Last Post: 30th Jan 2011, 05:47 -
Corrupted MOV file shows up as MPG
By jblc in forum Video ConversionReplies: 0Last Post: 10th Jan 2010, 14:15 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 22:40 -
Video but no audio in MOV file
By alegator in forum AudioReplies: 3Last Post: 18th Jan 2008, 16:43 -
Is it possible to split the Audio and Video from a Quicktime .mov file.
By StuartB4 in forum Video ConversionReplies: 6Last Post: 12th Jan 2008, 21:02
