I want to demux a QT movie but can't seem to find anyhting that will do it, apart from Mac apps.
Is it possible to do it on a Windows PC.
Thanks.
Thanks Baldrick but just tried but after loading the qt file the Demux options on the File menu are all greyed out/disabled.
Any other ideas?
Thanks. -
This works for the .mov apple movie trailers, but it's a roundabout way that just copies the h264 video and aac audio streams and repackages into an mkv container to extract them.
1) Open your .mov in avidemux, set video & audio sidebar to "copy", set container to mkv
2) Save but make sure you enter the location and extension (e.g. filename.mkv)
3) Open your new mkv with mkvextractgui
4) Extract your streams
I'm not sure why you would want the separate streams? Avidemux can encode, edit QT .mov files natively
Cheers -
W/O Streamclip (or similar), you'll neve be able to do it w/ just QT (free). W/ QTPro, it's as easy as pie...
Just open file, and [delete] tracks and then [save as] (self-contained), or if you want them to be different filetypes than MOV, [Export].
Do it all the time...
Scott -
Thanks Cornucopia. Works perfect.
I did'nt realise at the start, you have to show the movie properties in the Window menu of QT Player.
Thanks for the help.
I know It's a bit late but happy new year.
How do I find out the framerate of a Quicktime MOV video file?
By Dr.Rock in forum Video ConversionReplies: 3Last Post: 10th Sep 2012, 19:37 -
Is there a way to normalize a .mov file in Quicktime ?
By abrand88 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Apr 2010, 13:03 -
I can't edit this mov quicktime file
By qisheng in forum EditingReplies: 19Last Post: 1st Dec 2009, 04:05 -
Add an 2 video/Audio tracks to a .mov file without using Quicktime
By thomas31388 in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 16:35 -
Converting (Quicktime) .MOV file to .WMV file
By stanislawski in forum Video ConversionReplies: 2Last Post: 6th Feb 2008, 19:19
