Hi, I downloaded the "Large" guided tour for the MacBook Air from the Apple website:
http://movies.apple.com/movies/us/apple/mac/macbookair/2008/apple_macbookair_guidedtou...15_848x528.zip
It's a 184MB MOV file. When I try to play it with Quicktime Player it shows video but no audio. Just to discard problems with my Quicktime Player I upgraded to the latest version (v7.4 with latest updates) and downloaded other MOV files to test and it plays them fine with both audio and video, so the problem seems to be with this file alone. Mediainfo shows the details attached below for the file. Anyone can provide a clue as to what's causing this? Thanks.
General #0
Complete name : C:\Documents and Settings\Dell\Desktop\apple_macbookair_guidedtour_ 20080115_848x528.mov
Format : QuickTime
Format/Info : Quictime movie
Format/Family : MPEG-4
File size : 185 MiB
PlayTime : 7mn 51s
Bit rate : 3282 Kbps
StreamSize : 262 KiB
Movie name : Apple - MacBook Air
Movie name/More : www.apple.com
Encoded date : UTC 2008-01-16 00:07:33
Tagged date : UTC 2008-01-16 00:07:45
Copyright : © 2008 Apple, Inc. All Rights Reserved
Comment : Encoded and delivered by apple.com
Video #0
Codec : H.264
Codec/Info : H.264 (3GPP)
PlayTime : 7mn 51s
Bit rate : 3230 Kbps
Width : 848 pixels
Height : 528 pixels
Aspect ratio : 1.606
Frame rate : 23.976 fps
Bits/(Pixel*Frame) : 0.295
StreamSize : 182 MiB
Encoded date : UTC 2008-01-15 21:44:06
Audio #0
Codec : AAC LC
Codec/Info : AAC Low Complexity
PlayTime : 7mn 51s
Bit rate : 48 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 32 KHz
Resolution : 16 bits
StreamSize : 2.70 MiB
	I don't why it wont work in quicktime 7.4 but it works fine in mpc with quicktime alternative.
	Baldrick, I have not tested yet quicktime alternative as installation requires quicktime player to be uninstalled.
 I tested playing the Ipod sized Guided tour of the same video (22MB) and surprisingly my Quicktime Player plays it fine (with audio). I checked it with Mediainfo and the Audio component is also AAC LC, 2 channels but 24KHz instead of 32. Maybe Quicktime is having trouble with 32KHz?
	Try to use VLC player (free - http://www.videolan.org) to convert audio and video via wizard
 or MediaCoder (free - http://mediacoder.sourceforge.net/download.htm) plus "Extra Codecs Pack" from same link.
  MOV (MJPEG) file - audio but not video in VMC (using Haali and ffdshow)By enoesque73 in forum Video ConversionReplies: 5Last Post: 10th Jan 2010, 17:17
  Add an 2 video/Audio tracks to a .mov file without using QuicktimeBy thomas31388 in forum Video ConversionReplies: 0Last Post: 24th Sep 2008, 16:35
  Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 23:40
  Is it possible to split the Audio and Video from a Quicktime .mov file.By StuartB4 in forum Video ConversionReplies: 6Last Post: 12th Jan 2008, 22:02
  How to add another audio track to a MOV video file for macsBy VidHunter in forum MacReplies: 7Last Post: 31st Oct 2007, 01:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
