is there a free program that will do it with good quality?
Results 1 to 15 of 15
DVD Shrink can do this.
He's a liar and a murderer, and I say that with all due respect. -
sorry i should have said with no compression. cut the dual into 2 dvd's with menus. no shrink
You can do it with DVD Shrink or VobBlanker.
I've never used CloneDVD but regardless of what you use, the only way to keep it 100% is if everything you want to put to each disc will fit.
Just because it say's "Shrink" in the name does not mean you HAVE to shrink anything.
Say if on one you want to keep menus & the main movie & the second the menus & extras, if the main movie is larger than the disc you will have to shrink it some so you won't keep 100% quality no matter what program you use. -
I've found this guide to be extremely helpful. Exactly what I wanted. You keep the original quality and menus. http://jsoto.posunplugged.com/guides/VobBlanker/splitdvd9/index.php
I've found that doing the 'optional' part he mentions is quite important. Also, some DVDs require a bit more work with Vobblanker than the guide shows if you want the second disk to come out just right...Not a problem once you try a few.
BTW, I ripped the DVDs first using DVDFabDecrypter or DVDDecrypter in File mode.
Hope it helps you as much as it helped me.
P.S. I found that guide in this post, https://forum.videohelp.com/viewtopic.php?p=1464354&highlight=#1464354 -
A simple task, could be done with DVDremakepro. You could blank out ALL extras&ads, and back-up the movie w/menus on disc 1.
Second disc, the opposite. Blanking out the movie but leaving the extras w/menus.
Although you may still have to compress the main movie a bit to get it to fit onto a DVD-R. However, it wouldn't be much to scoff at. 90%-95% of original quality maintained. -
dvdshrink cannot (alone) do it while retaining the menu. vobblanker or clonedvd2 can.
i personally use DVDShrink to do movie only then i use titlewriter to readd the original menu. reason i don't just use vobblanker or clonedvd2, is because either of them can set an exact start/end point, only selectable spots. vobblanker can cut in the middle of a cell, but this can cause stuttering if used with DVD Rebuilder. -
thats my method. i do it with 95% of my dvd backups. i also do it with tv series dvds. if they have 4 eps on a disc i split it to have 2 disc's with 2 eps each keeping original menus. no quality loss. another way to make sure there is NO compression if after doing this method your movie is still a little too big to fit on a dvdr is to remove unwanted audio tracks from the main movie i remove all non english tracks and usually any commentary tracks also. can sometimes save 200 - 800mb depending on the movie. apart from the ripping of the disc all steps can be done with dvdremake pro. well worth the small fee for the program and done with a graphical user interface also unlike some programs. my steps are. rip with dvd decrypter or dvdfab decrypter then edit with dvdremake pro then burn with imgburn.Originally Posted by [url=https://www.videohelp.com/tools?tool=SUPER_1
Originally Posted by resohedJust so nobody get confused, dvdremakepro is not free, nor does it (in any way) produce output with superior quality to what can be done with VobBlanker (which is free)....could be done with DVDremakepro...
Thank you, redsandvb, for posting the link to that guide. I missed the post by BSpielbauer where you learned about it. It's very well written guide. -
No prob.Originally Posted by VegasBud
Yeah, I saved that page to my hard drive. Great way to make copies. 8) -
Yes. Ifoedit (freeware) with this guide https://www.videohelp.com/guides.php?guideid=248#248 A little involved but I've followed this guide on 3 or 4 backups when I first started out 4-years ago and achieved desired / expected results (DVD9 split across 2 DVDRs with all menus and original quality).Originally Posted by resohed
DVDRemakePro is not free, but its SOOO worth it!Originally Posted by VegasBud
Its so easy&straight-foward, saving MANY headaches and frustration. Also a great program to use for any future DVD stuff. Getting rid of and or editing stuff with it, is a snap. -
Yeah, I've seen him promoting DVDRemake Pro in a number of threads. Sure, it's a good and useful program. Personally though, about all I find it good for is merging 2 or 3 DVDs into one, keeping the menus, which is very difficult using freeware. Other than that, most of what it can do can be accomplished just as easily, if not more easily, using VobBlanker and/or PGCEdit. Like the original question in this thread. I don't really find its use very intuitive, although I would, I'm sure, with more experience with it, and the terminology it uses, in many cases, is the creation of the developer and difficult to understand.
And, as stated, it's not free, a prime requirement of resohed.
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 01:02 -
How do I seperate 2 discs froma single dual layer 8 gig VTS files
By xkeots in forum MacReplies: 3Last Post: 11th Nov 2007, 10:48 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39 -
Weird. Menus that you can see in dvdr disappear in dual layer.
By Talayero in forum Authoring (DVD)Replies: 18Last Post: 27th Aug 2007, 02:14
