Does anyone know the best tool for converting dvd9 to dvd5 with no errors after ripping with dvd decrypter?
How about you start by ripping them with no errors in the first place ? DVD Decrypter has not been improved in a long time now. Copy protection has moved on. Rip with DVDFab HD Decrypter or ANYDVD (latest versions of either), and most other tools will work fine.
My personal preferences are DVD Shrink for simple re-authoring, and DVD Rebuilder with HCEnc for major reductions.
But if you don't rip it correctly to begin with, it really doesn't matter what you try to use next.Read my blog here.
12
Last edited by Anonymous4; 11th Mar 2017 at 11:20. Reason: Scrubbing myself from the Internet.
Not quality per se but there are some issues as to whether or not the "ripped" DVD follows the requirements for compliance to the DVD standard. Especially when the ripping program tries to remove or correct some of the "protections" put in DVDs these days. It is possible that when one tries to reduce the ripped DVD9 to DVD5 by either shrinking or re-encoding problems may occur if the ripping program hadn't handle these correctly. RIPIT4Me used to clean up some of these problems with rips, but it has been discontinued and is no longer updated to handle newer "protection" schemes.Originally Posted by DeXeSs
As Gunslinger pointed out in his post, there are programs that are more current and better able to handle some of the newer DVDs. I use DVDDecrypter coupled with RIPIT4ME to do backups when possible - still works for most disks. I use DVDFab HD Decrypter if the former programs can't handle it. The newer programs are updated quite frequently to deal with this. Think of it as a cat an mouse game.
On conversion from DVD9 to DVD5 I usually use DVD Rebuilder (Pro) using the HCEncoder. DVD-RB does an excellent job and on my machine doesn't take significantly more time that DVDShink in deep analysis mode. I use VobBlanker to remove extra advertisements etc. although other tools such as PGCEdit can do this also. There are options as to how the disks should be ripped with DVDFab built into the program (similar to what DVDShrink offers).
rcubed
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Converting Dual Layer DVDs to AVI (Video Footage More Than 2 Hours)
By cucuzza in forum Video ConversionReplies: 2Last Post: 17th Sep 2010, 18:54 -
Encoding in 720p to single or double-layer DVDs?
By broaddd in forum Blu-ray RippingReplies: 2Last Post: 11th Feb 2009, 23:41 -
Splitting 8GB DVD into 2 single layer dvds
By omega_weapon in forum ComputerReplies: 4Last Post: 16th Aug 2008, 11:17 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39
