Hi,
I have in my hard drive an 8 gig live show that I dl'ed but it is from a dual layer and it is 8 gigs.
I have a single burner and I do not know how to seperate the set into 2 discs.
Is there any free ware out there or can I just re label the VTS files?
Can someone please give me advice.
X
You could re-compress the show to fit on a single layer disc. There is this quite fast process called requantizing to do so. DVD2OneX is made just for this. Also Toast's Fit-To-DVD option does this. Neither is freeware.
You could split the show in two parts. MPEG Streamclip can do that for continuous video. You'll lose the menus and such and have to author it as DVD again. The app is free, but it needs a $20 QuickTime component to read MPEG-2 video.
Re-labeling the VTS files won't give you a valid DVD. The structure is a bit more complicated than that. -
Thanks..............I just did a trial dl of dvd1x1 and i will let you know if it is all good.Originally Posted by Case
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
How i can make multi avchd dvd single layer discs with tsmuxer?
By fits79 in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Nov 2011, 09:09 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Ok, best tool for converting dual layer dvds to single layer dvds is?
By burgkev in forum Authoring (DVD)Replies: 5Last Post: 25th Aug 2008, 02:02 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
