A super easy way to backup your copy protected DVDs!
This program is a freeware utility that serves to help you backup your copy protected DVDs.
Recently released DVDs are now very often equipped with stronger copy protections - such as ARccOS™ and RipGuard DVD - that programs like DVD Shrink or DVD Decrypter have problems handling.
With the help of RipIt4Me, ripping these DVDs will be very easy. The program is fully automated and the wizard will guide you thru all the necessary steps involved. If you prefer, there is also a true "1-Click" mode that will perform all the involved steps automatically for you
http://www.digital-digest.com/software/RipIt4Me.html
Results 1 to 30 of 50
Sounds good. I await the reviews.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Well I tried it and I like it,you only have to set the output in DVDShrink and you have a two-click backup.The only problem I can see is if DVDDecrypter(with PSL file) can't rip the newer forms of copy-protection,in that case I will have to use DVDFab Decrypter.
Apparently, it uses DVDDecrypter as the ripping engine, and FixVTS to clean up the files. That's fine, as it's meant for beginners.
I assume it sets DVDDecrypter to ignore read errors and shove in dummies, which is pretty much what DVDFabDecrypter does. IIRC, Fab does 4 retries. Then FixVTS to clean up the "junk". There's no mention of it generating a protected sectors list (PSL), which is the way to get a truly "clean" rip of an ARccOS disc. Nevertheless, it does have the advantage over Fab in doing a cleanup. [shrugs]
[EDIT] It should be okay, and Moviegeek has provided the first review.Guess I'll try it too, as if I don't have enough rippers...
Pull! Bang! Darn! -
Just tried it on a Ripguard disc. No problem.
Checked the log, it DOES create a PSL file, so ignore my objections above. This one's looking quite good, and is rather more noob-friendly than PgcEdit.
[EDIT] It's so simple, you'd think a guide would be unnecessary, but here it is:
http://www.riphelp.com/RipIt4Me/guide.htm
An interesting discussion here:
http://forum.digital-digest.com/showthread.php?t=67918
Reported to work on Ultraviolet and Underworld. Did Narnia for me, nice clean rip. Funny thing is, it's very quick, considerably faster than the PSL2 Plugin Wizard for PgcEdit.Looks like a real find.
Pull! Bang! Darn! -
While I'm a big believer in "If it sounds too good to be true...", this program certainly seems to be the exception to the rule. Even though I had already successfully used the PSL2 Plugin for PgcEdit on my Ultraviolet disk, since it has the newest protection attempt I ran RipIt4Me on it for a comparison. After it completed, I opened the rip in assorted programs known to be picky. All of them seemed perfectly happy with the rip. PgcEdit doesn't even offer to fix anything.
This program not only uses the genius of other programs to complete the rip, but is also doing quite a bit of work itself. As an example, I couldn't figure out why the DvdDecrypter ripping part wasn't putting up the standard error reporting message boxes when it hit a bad section. Reading the log after it finished, I found that the program itself is parsing the dvd and creating a PSL2 before it ever calls DvdDecrypter. After the DvdDecrypter stage, it did a structure cleanup all on its' own, before it calls FixVTS.
It's fast, easy to use, appears to do an excellent job, and is free. What more can you ask for? -
Sounds good - has anyone submitted it as a new tool?
https://www.videohelp.com/toolsedit.php?newtool=1There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Nice tool, will be interesting to see upcoming versions.
You might want to check the new program RipIt4Me described in this thread https://forum.videohelp.com/viewtopic.php?t=303745 It sounds like a very well done product. The problem with DVD Fab Decrypter is thats it't pretty crude and heavy handed.
Originally Posted by SCDVD
RipIt4Me, well, can't see anything wrong with it. I wish the scroll bar on the RipIt4Me window would work when the associated programs are running. A minor quibble. Gunna be watching for user opinions on this one.Pull! Bang! Darn! -
[quote="fritzi93"]
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
[quote="jeanl"]
Originally Posted by fritzi93 -
Oh I see....
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
I use DVDFab Decrypter on scratched discs when DVDDecrypter or IsoBuster can't read them.
BTW...nice update of FixVTS jeanl,the new version works perfectly. -
Sometimes a sledge hammer is a very useful tool but they aren't generally that good for watch repair. If there is no other way to read a disc because of scratches etc., DVD Fab Decrypter can save the day. But since ignoring real read errors often results in a damaged or corrupt file, the copy may need to be repaired.
Thanks man!
The program works for me, but I have to disable AnyDVD first or else it will error with the following messaage and shut down.
RipIt4Me has encountered a problem and needs to close. We are sorry for the inconvenience.
Used Sony's Legend of Zorro for the test rip. Went through all the steps and the resulting back-up seems to play fine. -
Version 1.1.0.0 has been released! I'm indeed liking this program
Originally Posted by r3n4ud
I'm curious what got improved/fixed.
[EDIT] Damned if I can find a changelog, but a member at the digital-digest forum posted this:
Version 1.1.0.0
* Added code that detects cells that have been erroneously removed. The code warns the user if there's a chance that the cell was removed because the DVD was scratched.
* Fixed a bug in the code that checks for Decrypter on startup.
Right out of the gate this program is sophisticated. The erroneous deletion of cells was always one of my gripes with DVDFabDecrypter.Pull! Bang! Darn! -
Here are the changes:
Fixed a bug in the code that checks for Decrypter on startup. -
rvelez, heh, I was editing my post while you were replying. :P
Pull! Bang! Darn! -
I noticed something strange between 1.0.0.0 version and 1.1.0.0 version of RipIt4Me. The first version will show "You're using DVD Decrypter version: 3.5.4.0" each time I open the program but on version 1.1.0.0, it only shows the Decrypter message the first time (when the .ini and log files are set up) but never again after that. Has anyone else noticed this? I do have "Check DVD Decrypter at startup" selected on both. I'm attempting to include a pic of both versions, I hope it comes through.
ripit4me.jpg"The fittest shall survive yet the unfit may live."
--DEVO -
Originally Posted by cyflyer
Checking around a bit, the only reported problems (so far) turn out to be operator error:
1) Not setting paths correctly to DVDDecrypter, FixVTS, and DVDShrink. Or even failure to have on one's computer any/all of the above.:P
2) Having AnyDVD or DVD43 running when trying to use RipIt4Me.
As to paths, if you already have the required programs on your computer, RipIt4Me finds them automatically.Pull! Bang! Darn! -
Originally Posted by rvelez"The fittest shall survive yet the unfit may live."
--DEVO -
That's correct. It checks the first time. Since Decrypter is no longer updated, once it detects you have the latest version, there's no need to check it again.
--DEVO
Best ripping tool for Windows 7 64bit
By Hal05154 in forum Blu-ray RippingReplies: 8Last Post: 13th Nov 2011, 20:12 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
BR to .mkv ripping tool (no video encoding but with chapters).
By meico1234 in forum Blu-ray RippingReplies: 0Last Post: 11th Nov 2010, 06:59 -
Best DVD ripping tool?
By bkkfrank in forum DVD RippingReplies: 4Last Post: 6th Oct 2009, 12:54
