I may be able to get a new computer this summer, and if I do I am wondering how best to optimize my purchase to get the best performance for backing up my DVDs.
I won't need to get a monitor, keyboard, etc. If all goes right, I should have about $600-800 to spend. I am hoping I can get opinions (with rationals) for what I should look for.
I basically back up my own DVD collection (always increasing in size), and occasionally make a DVD from VHS tapes using my JVC DVD writer and TMPG DVD-Author. Once in a great while I convert VCD's to DVD, but only a couple times a year, I mainly re-encode using DVD-RB onto DVD-5's. I have a DL burner, but have never used it to make a DL backup disc (don't even own any of those discs, waiting for the price to come WAY down).
Where would I get the most bang for my bucks? I'll probably order from tigerdirect.com or someplace like that (I personally can't build my own).
I already figure a huge HDD (160GB-250GB) of course, maybe even 2 if I can afford it, and a 16x DL-DVD burner (those seem pretty standard now anyway).
What about a processor and/or motherboard though (no idea what I should consider)?
And how much of what kind of RAM should I get?
Should I get a dedicated video card instead of just relying on what's integrated on the motherboard?
Please, any thoughts/opinions on this are appreciated - thanks all!
Results 1 to 30 of 34
Here are a few answers:
- Get an ASUS motherboard. In my experience, they are the most rock-solid boards out there, even if they cost a little more.
- AMD vs Intel? Look here! If it is a video encoding station, use a P4. If you want all-round performance but slightly slower video performance, get an AMD. If you go with AMD, make sure it's an nForce4 board - I have a VIA board, and it's terrible.
- In my experience, Pioneer DVD writers are the best, although many people here have also had good experiences with other brands and I'm sure you'll hear about it also - they're probably all much the same now, anyway!
- Hard drives - try and get a SATA drive, purely for airflow and neatness (there's no real performance advantage to them)
- If you buy an expensive motherboard, it will most likely not have a graphics card built-in. I would go for a cheap nVidia card, but ensure that it supports DirectX 9. This will enable your new machine to run Windows Vista with all the nice visuals, should you want that.
- Memory. Dual-channel kits are always nice, but I'm not sure how much of a performance boost you'd get from them for your purposes. Crucial seem to be the only brand of memory that I have used that always works out of the box - other brands sometimes work and sometimes fail the MemTest86+ tests. 1GB of RAM should suffice, although this is the minimum for Vista (or so I've heard). You can always add more later - most motherboards have four RAM slots now.
- Go for a semi-decent case - you'll not regret it when you're building it.
- Power supply - don't skimp on this! I did, and it cost me dearly when it died. I'm using an Antec TruePower PSU - very quiet, and provides all the power I need. I hear good things about the Enermax PSUs as well.
- Invest in a few decent case fans. I assume this machine will be tucked away somewhere, so it doesn't matter if it's a little louder. Decent cooling will ensure it stays reliable.
I think that's about it. Hope there is some useful stuff in amongst all that...
Cobra -
Go with msi motherboard , solid performance over lifetime of pc , asus have issue's .
Or gigabyte .
Ps : Try getting one using sis chipset , not via (very reliable) , should you want to use linux (lack of via sound support) .
512 minimum memory .
Amd 64 cpu's for ALL round performance (use xp now , 64bit later) ... p4's have serious flaw's in processor code which could cause pc crash if triggered .
Sata hd's by seagate , better than maxtor , western digital .
Dvd burner's - lg (support's all media type's) , sony next best , third is pioneer (can have issue's) , liteon is bottom of pit when it come's to cross compatability .
Onboard video will save money , and prevent you from playing the dreaded "catchup" game , as these card's change frequently .
Go with a standard case blank , one that is strong in constructional design with plenty of expandability for drive configurational option's , like those mac cases's (filtered air passthough's)
Power supply , the best you can afford from antec or other , 500 watt and up .
Last , consider after market cpu and case fan will prolong the life of the unit (never overclock) .
Considering what is listed here , I build system's this way , and have never had any customer complaint's ... I see these people all the time and ask how the pc is going ... most ask me how to do thing's in program's . -
Do you have a source to back this up? I've never heard of that.Originally Posted by Bjs
I think what is being referred is the known hyperthreading issue with certain intel branded boards that causes crashes. There is a report on the intel forums about this.
What I would really question here is the false statement that Intel is a better video encoder or a faster encoder. I have found just the opposite to be true unless you purchase the top Intel chips and compare them to an Athlon64 for encoding times. Intel has really fallen behind AMD in the last 6 months. -
Really? Apologies - I didn't realise. As you can see, I wrote that a while back and assumed it was still the case (no radical changes in architecture of either chip).
I have avoided using Intel boards for Intel Chips preferring to use third party boards. I wonder if Intel ever released a BIOS update or other fix that corrected this issue? I believe it was only a few makes that had this issue. Then again, I might be referring to something completely unrelated to what Bjs is talking about.
///////////Originally Posted by nathanaa
Hi,
my opinion...
I pay attention to the speed and ram if your going to do video editing and vhs copying...
for example rendering... the faster your cpu speed the better.... rendering is very cpu intensive... and if you do a lot of manulation of a video file.... then a lot of ram come into play...
Now along with a fast cpu chip..... the motherboard bus speed become important also.... i would make sure you get a mother board that has bus speed of 800 mhz... So for a few dollars more yo can gain a lot of performance that you need....
I would maybe get at least a 3.0 gig cpu chip.... with at least 1 gig of ram and the motherboard has buss speed of 800 mhz ...... and depending on how much money.... left... on the graphic card.... right now... there appears to be general agreement the ati 9600 series is very good.... and a good sound card.......
note: I stay away from embedded grphaic chips and sound chips that in the motherboard itself........ there seem to be a lot of issue if the components is embedded versus seperate card..
well those are my thoughts...
I haven't check the component prices for a while but a lot of those things have really come down in price and I think you can stay in that 800 dollar range fairly easy... -
Looks like you're getting a lot of useful AND conflicting information. So allow me to add my 2 cents worth. The best peice of advice you've seen here is to get a good power supply. 50% of the unstable computers I repair are because of a faulty or underpowered PSU. Go with a PSU that is at least 400+ watts from a reputable manufacturer (any reputable manufacturer will most likely work). My personal favorite is Fortron, followed by Thermaltake and Codegen, but Antec has always been the Cadillac. For the most part, a case is a case is a case. If you spend $40 or more on a case, it'll probably do the job just fine. Asus is not better than MSI and vice versa. Every manufacturer has problem boards and great boards. It's best to decide what processor you're going to use and then choose the motherboard. Any of the better known manufacturers will probably serve you will, although they each seem to serve different niches, Asus is the Cadillac in this group, but MSI, GigaByte, Abit, Epox, DFI, even Asrock are all good manufacturers. There's a lot of anti-VIA chipset sentiment, but I've used them 4 to 1 over everything else and never had a problem with them. Get 1GB of RAM, I too use Crucial almost exclusively, mostly for its lifetime warranty. This is the one place you do not skimp. Get good RAM; Crucial, OCZ, Kingston, Kingmax, Viking, Corsair, Geil, Mushkin are all good brands. Video cards only really matter if you are going to be doing much gaming. Otherwise, anything over $75 from nVidia, ATI or Matrox will be great. Avoid having to use onboard video, it slows down your system and makes your motherboard obsolete when newer more demanding programs come out. Get a HDD(s) that gives you the most storage for the buck. They're all pretty good right now. I would suggest at least a two HDD setup for DVD-RB. Put the ripped and encoded video on one disk and put the temp folder on another HDD, it will speed it up. SATA is cleaner, but offers no real performance advantage. For video/audio encoding, mHz are what matters, period. This is the one arena where Intel can still beat AMD, but not by much. A 3.0 gHz Intel processor will encode faster than an AMD 3000+, because the AMD is actually running at 2.2 gHz. For just about anything else, an AMD will give you much more bang for your buck. If the mHz are equal, the AMD is going to slaughter the Intel. Dual core would be nice, but will probably be price prohibitive in this price range.
Anyway, decide whether you're gonna go AMD or Intel and when you're gonna do it and I'm sure we can get you a sweet system for $600-$800. Good luck.
-Brett -
Intel P4 CPU suggested for video
1GB RAM
Seagate or Western Digital hard drives only, absolutely DO NOT buy the cheaper and crappier Maxtor or Hitachi junk
You can use integrated audio and video if on a budget, but for best performance, shy away from that. Video is the bigger issue, audio only if you want to capture video on the system
Get a good motherboard. Asus or Intel for INTEL CPU. nVidia for AMD CPU. Avoid VIA boards (or anything with VIA chips on it), they are garbage and the drivers are pathetic, lots of problems to be had here.
Pioneer DVD burner. Maybe NEC, LG or LiteOn if Pioneer is not available. Avoid the others if you can.
Looking at your requirements, you can probably cut a lot of corners on audio, video. You can probably even skimp on RAM to save some bucks, go for 512MB, will work just fine for what you need. May not need the newest CPU either, get one that is a tad slower, from a couple years ago, but still sold new and in stock.
Microcenter and Fry's, and newegg.com, I bet you could build a computer for $400 or less. It's possible. If you wanted, you could even grab some good deals off eBay off used stuff.
You can probably find a good motherboard with a P4 1.5-2.5Ghz and RAM on eBay for $100 or less. Just be careful. Worked for me, did it last month for somebody.Want my help? Ask here! (not via PM!)
Well if you don't want to build yourself - this package from BestBuy (in store or online, your choice) is a good performer at a good price point ($499, no rebates necessary). I went yesterday and tried to buy it without monitor, they said $509. The manager said I should look at clearance merchandise if I didn't want the monitor. The salesgeek then found the exact unit, sealed box, on clearance for $449 without monitor, go figure. Threw in NAV free. Now setting up for a family member. Athlon64 3400+, 1gb RAM, 200GB HD, DL DVD Burner, 9-1 card reader, nVidia 6100 graphics with extra PCI-X16 card slot
I find that some of the Fry's and other machines save money on an inferior specification like 512MB ram, Sempron or Celeron CPU, 80GB Hard drive, or the dreaded "integrated Intel 945 or SiS video" which you should avoid like the plague. If you cannot get an upgrade PCI-X video card into a unit, then things like Vista or some cool midrange game won't work.
Sure a high range P4 might edge an Athlon64 3400+ by a bit but not enough to pay $100 more for. I have a P4 3.4GHz machine myself for video but I built it with some of the parts recommended above - I spent more money than you are budgeting for though.
Shop around, there are good machines out there.
The KittyPanasonic DMR-ES45VS, keep those discs a burnin' -
My new computer will primarily (almost exclusively at first) be for video re-encoding and rendering-type activities. I don’t think I even own a computer game, much less play them, so I don't need that type of system or performance. My old computer will work fine for email and surfing the web, word processing, etc. If I can get this new one, it would be primarily for video work. Heck, I’m even planning on using some *old* keyboard, mouse, monitor, etcetera stuff I have laying around with it, as I don’t plan on actually *using* it for much else.
With that in mind, these are the specs recommended by you folks so far:
- case: average quality case (I don’t care what it looks like)
- cooling: CPU fan and several other cooling fans (brand??)
- CPU: Intel P4 3.0+GHz
- DVD burner: 16x DL DVD+/-R/RW (Pioneer)
- HDD: dual SATA drives (160-250GB+ Seagate)
- memory: 1GB RAM (Crucial)
- motherboard: ASUS or Intel, w/ 800Mhz FSB
- power supply: 500w + (Antec TruPower or Enermax brand)
- sound card: ??
- video card: nVidia with DirectX 9 support
The video and sound card are if I choose a motherboard that does not have them onboard. It sounds like that would be a good idea, am I correct in assuming because it would speed up the re-encoding process?
Are there any other specs or considerations I should be thinking about? Oh, and any recommendations about the sound card? -
- case: plenty of fans, nice slots to hold everything, including drives (including ones you may add later), probably run $50-100 for a nice one
- cooling: CPU fan and several other cooling fans (any brand)
- CPU: Intel P4 3.0+GHz with 800mhz FSB
- memory: 1GB RAM (Crucial or Kingston or whoever)
- motherboard: ASUS or Intel, w/ 800Mhz FSB FSB is the CPU, not mb
- power supply: 500w + (Antec TruPower or Enermax brand or whoever)
- sound card: soundblaster (not audigy) or turtle beach
- video card: nVidia with DirectX 9 support or ATI
That works.Want my help? Ask here! (not via PM!)
Another thought I had - exactly what *kind* of RAM should I be looking at? I don't know what all that DDR, DDR2, EEC etcetera stuff means. When I did a search for Crucial RAM at tiger there were a couple dozen choices, and I have no idea what would be my best option.
And is a higher mhz better there too? -
It depends on the motherboard and chipset,IMO DDR2 isn't worth the cost.ECC=Error Correcting Code,it's better to have but it also depends on the motherboard.Originally Posted by nathanaa
I also recommend ASUS boards but stay away from VIA chipsets(bad experiences)!
"And is a higher mhz better there too?"
Yes,that's where you will get the best "bang-for-the-buck".Always use the same speed as the CPU,you can use slower RAM but performance will suffer. -
Ok, thanks. Would it be a good idea to get a memory cooling kit? I just found out about them when looking at memory tonight. At less that $10 it can’t hurt I suppose, or would it just be completely unnecessary for this type of system?
My gear:
- JVC HR-S9911U SVHS VCR
- Datavideo TBC-1000
- JVC DR-M10 DVD writer
- Sony Steadyshot DCR-TRV340 NTSC Digital8 Camcorder -
I'd suggest you get a good aftermarket heatsink and fan for that HOT INTEL processor. Thermaltake, Zalman and Swiftech are good brands for heatsinks. Vantec has good case and cpu fans. AMD 64 processors don't need the aftermarket heatsinks because they run cool on stock heatsink and fan. I have a AMD 64 VENICE 3200 that runs at the temp of 42c when using DVDRB-PRO. My P4 Northwood 3.00c runs at the temp of 54c when using DVDRB PRO. If you want fast encoding get the P4 INTEL processor but get a good heatsink fan because the P4 processors that came after the P4 NORTHWOOD's have high heat temps. Just my 2cents!
If you are going to be doing a lot of video encoding, consider getting a Pentium D (i.e., dual-core).
Regards.Michael Tam
w: Morsels of Evidence -
or a dual core AMD.......as you can see, there's a lotta varying opinions on the processor...if you go amd, stay away from semprons...same thing with intel, if you go intel, stay away from celerons.....those are their base level garbage that they shovel out to the masses....my main gripe about intel processors (other than the fact that they spend a ton of money on advertising instead of properly investing it into their actual processors) is the heat factor....your gonna definately want extra cooling for a p4 rig, especially if it's gonna be running heavy loads such as video encoding on a regular basis.....AMD rigs can generally speaking, do okay with the standard fans that are included with the processors....personally, i run an AMD 3700 myself and it's been going for around 3 solid days, it's running at 38C right now, but i have seen it top out at around 50-55 during very CPU intensive stuff, as opposed to p4's which idle at around 45-50 and can top out at like 65-70C......needless to say, heat isnt a good thing, it can (under improper cooling circumstances) start to cause damage to parts of the computer that and if the processor continually runs hot, it can actually burn out your processor faster as for brands of ram, personally, i'd recommend OCZ just cuz they lifetime warrenty their ram, so IF for some god forsaken reason, your ram would act up, ya just send it to them and they either fix it or replace it outright....as for the harddrive, i'd have to disagree with those that said seagate.....i've had better luck personally with WD and even maxtor (i know im definately in the minority with maxtor) but i do agree with the opionions given so far to use SATA not only cuz it looks cleaner, but then you dont have to deal with jumpers and that type of thing...as for the video card and sound card, if this is gonna be used EXCLUSIVELY for video encoding, it wont make a huge differance except maybe playback if your intending on doing any of that, it wont make any significant differance in your encoding (unless you use that ATI video encoding thing, but im not too sure about the quality of the results, or if a vid card that actually does use that would be within your price range...i dont keep up on price ranges of vid cards unless im specifically shopping to replace mine) memory cooling....personally i havent found that it makes a significant impact, but feel free, i dont see that they would cause any harm...dvd burner...personally i stick with lite-on myself and they have worked great, others have reported NEC work pretty good as well......(though i've appearently had some bad luck with the one i had)
I'm another Maxtor & WD hard drive buyer as well.i've had better luck personally with WD and even maxtor (i know im definately in the minority with maxtor)
I still have a little old 6gb WD from my first computer and it still works.
Nathanaa buy what you can afford. Personal preference for me is the BENQ 1640 & 1650 dvd burners. LITEON just acquired BENQ's optical dept. so it will be interesting to see what kind of dvd burner will be released with the new merger.
whoa...i must be a bit outta the loop, i didn't hear about that....should be interesting to see though..Originally Posted by budz
Well, I looked at the Pentium D processor, and it does sound like it would be a much better choice for what I plan on using the computer for (mainly). It's a bit more expensive, but sounds worth it.
However, matching it to a mobo seems like a problem. If I plan to get an 800mhz FSB processor, and 800mhz DDR2 RAM, I need to get a mobo that will *take* that kind of RAM. I'm having a problem finding an ASUS/Intel mobo that fits all those criteria. Unless I'm just missing something. I'll keep looking, but anyone got any recommendations?
Oops, forgot to mention - I'm looking for a board with both USB and Firewire on it (so I don't have to buy the cards). Or would it be cheaper that way maybe, hmm.... -
I bought two of these recently.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131589 -
Dual-core and 64 bit and all that fancy stuff is going to blow your budget way past $600-800, and you probably won't need it all that much either.
I'm using a Northwood P4 2.8 and an AMD 2700+ (2.2) and these are plenty fast, they run circles around that P3 of yours. Do you want something faster and affordable? Or do you want the latest and greatest, and to hell with budget? Must make that decision.
A lot of that fancy dual-core/64 won't be used by software anyway, and then do not worry about anything other than Windows XP (preferably PRO and not HOME) for the OS. Keep yourself grounded and sensible, don't run into superdorkland unless you just want to go. But remember AT ALL TIMES that it's an optional trip, you can bypass it and be plenty fine for less $$$$.
The biggest problem with technology is people spend lots of $$$$ on crap they do not need and never will need.Want my help? Ask here! (not via PM!)
Thanks, I just found an almost identical board at tiger for the same price. The Asus P5WD2-P instead of the -E (I can't tell what the differences are). Just took me awhile to wade through the scores they had.
My gear:
Yeah Lordsmurf, that's kind of where I am at. The dual core thing would be nice, but it does put me way over the top of my expected budget. I don't need the latest & greatest, I want speedy performance at a reasonable price, which I can get within my budget.
Thanks for the reality check though, never hurts.
My gear:
Ok, I guess my next question is about the audio and video. If I just use the on-board audio/video will it *really* affect the performance or speed when I'm running things like DVDRB-Pro? If it will affect it, how much are we talking about? A few percent or something that I wouldn't even notice? Or a lot?
If it will make a big or even very noticeable difference in how long it takes to reencode something, then it's worth it to get separate cards as long as I can afford it - but like I asked above, how much affect does on-board vs separate cards really have?My gear:
Onboard video and audio will not affect anything you've mentioned you'll be doing, not so far. Those are shortcuts you can take, given your needs and wants stated so far.
If you were playing games or doing NLE work, or using the computer as a media center (where you watchs most DVDs, for example) the conversation would change.Want my help? Ask here! (not via PM!)
No, I watch my DVDs on my TV (or on my laptop when traveling, but that's another issue entirely).
So ok then, I can drop the audio and video cards to save some bucks from my budget for other things.
One other thing I thought of about audio though - with onboard audio, will I be able to hook my audio tape deck up somehow, so I could convert all my old audio tapes into mp3's? I’ve got a lot of audio recordings of interviews with my great-grandmother and similar stuff I did back in the 80's and 90's, I’d love to be able to get it into a digital format for future generations of the family. I’m guessing the RCA I/O audio ports would work, and just use something like Audiograbber? Or do I need to do more research on this issue?My gear:
Yes, onboard audio will do this, but will not sound great. For spoken word stuff from portable cassette recorders, though, this is a moot point. You can use the 1/8" stereo line in jack for this, and freeware such as Audacity or Wavepad work very well (and Audacity even has a noise reduction function to kill a bit of the hiss you'll have).
Will my computer specs support Blu-ray at all?
By takearushfan in forum DVD & Blu-ray WritersReplies: 19Last Post: 15th Mar 2012, 18:21 -
Calculate computer performance increase?
By ziggy1971 in forum Newbie / General discussionsReplies: 6Last Post: 9th Oct 2011, 09:11 -
Computer build questions on motherboard brands and cpu specs- vid encoding
By yoda313 in forum ComputerReplies: 68Last Post: 31st May 2011, 08:55 -
Recommended Computer Specs for DVD Backup?
By romero in forum DVD RippingReplies: 4Last Post: 30th Oct 2008, 07:46 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 11:31
