Hi
I need to know what the Still Performance of a sony DCR-TRV480?
I need to know what the Still Performance of a JVC GZMG130?
What do you mean by 'Still Performance'? Do you mean mean when the video is paused? That's mostly based on the file you are playing and it's quality and format. You would need to give more information to get a decent reply.
EDIT: Sorry, I missed that was a camcorder. That was some of that information that was needed.
Assuming you are reffering to the still camera ability where they will store the image file on memory card try www.camcorderinfo.com .
Overall the still capabilities of most camcorders are not that great, you're better off getting a cheap dedicated still camera. I have $2k Canon GL2 and I can truthfully say the still shots suck...
Video is another story though.
still shots
The only advantage to using a camcorder for stills (photos) is the long zoom lens. In almost every other spec, a digtal camera is superior.
The reverse is true for video.
Google those model numbers for Megapixel specs. -
Hi,
the file format + 3ccd compressed file can be enumerated for evaluating a good still performane.
Which is better for speed and performance?
By SIRCOOKS in forum ComputerReplies: 3Last Post: 20th May 2010, 22:03 -
Concerned about PC performance
By mattman1968 in forum ComputerReplies: 4Last Post: 23rd Oct 2008, 10:31 -
How can I tweak Vista32 for best Performance?
By nyfsmith in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 13:58 -
FFMpeg performance
By aeroliteflyer in forum DVD RippingReplies: 12Last Post: 18th Mar 2008, 19:47 -
CRYSIS performance
By retroborg in forum Off topicReplies: 4Last Post: 13th Dec 2007, 06:55
