Good, I was hoping that was the case. Thanks for the software tips, I'll check those out.
I'm having a problem finding the right mobo. If I got an Intel P4 3.0Ghz (w/800Mhz FSB, socket 478) and two Crucial 800MHz PC6400 512MB sticks, I need a mobo that matches them, preferably with both USB and Firewire. Tiger doesn’t have anything unfortunately, that I can find at least (from ASUS or Intel). All the boards I find seem to only take DDR RAM up to, at most, 667mhz, usually less.
I am assuming if a board says it takes DDR that DDR2 will work too. What I can't find is one that can take the RAM that matches the CPU FSB speed/power. I would appreciate any recommendations. I'm trying to follow the advice above about using RAM that matches the CPU, but maybe I won't be able to, in my budget range ($800 max)?
Results 31 to 34 of 34
Onboard audio is usually AC97, which sounds perfectly fine. I've got it on one of my Intel boards, and there is not problem whatsoever with it. It sounds every bit as good as my Turtle Beach and SoundBlaster cards (good cards). The ONLY issue with onboard audio is video capturing, it can cause sync errors.
If you plan to use this for playing media, watching DVDs, you can try onboard video, but you may want to grab yourself a decent ATI or nVidia card (again, used ones are fine, it DOES NOT have to be brand new $200-500 "latest and greatest", it just needs to be an AGP with decent RAM of 64MB or more).Want my help? Ask here! (not via PM!)
This is true. "Not great" means different things to different people (and for different uses), and the extra 10dB of noise (over, say, an Echo MIA) that might matter in a studio recording environment will not in home use.Originally Posted by lordsmurf
I haven't had any luck, so I'll repost this part in case anyone can assist me with this -
Anyone able to tell me about that DDR/DDR2 thing? Thanks for any help or direction.Originally Posted by nathanaa
Will my computer specs support Blu-ray at all?
By takearushfan in forum DVD & Blu-ray WritersReplies: 19Last Post: 15th Mar 2012, 18:21 -
Calculate computer performance increase?
By ziggy1971 in forum Newbie / General discussionsReplies: 6Last Post: 9th Oct 2011, 09:11 -
Computer build questions on motherboard brands and cpu specs- vid encoding
By yoda313 in forum ComputerReplies: 68Last Post: 31st May 2011, 08:55 -
Recommended Computer Specs for DVD Backup?
By romero in forum DVD RippingReplies: 4Last Post: 30th Oct 2008, 07:46 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 11:31
