Hi guys!
Haven’t posted on here for a while – posted on the capturing forum a lot!
I have a question with Adobe Encore 2.0.
I just bought it, and I took one virtual tutorial and have read two text tutorials, however, I’m having an ongoing problem that I just can’t kick!!
Every time I try to insert a Timeline (Ctrl-T) I keep getting the following error message:
If, for some reason, you can't access the link, here's the text of the error:
Could not import file FILE-NAME.avi.
Video files for this project must have a resolution of 720x480, 720x486, or 704c480.
At this point, all I want to do is start creating your most basic menu template for a DVD.
I’ve searched google ‘till the sun went down, but no luck!!!
Any help would be appreciated, I just don’t know what I’m doing wrong!
Thanks for reading.
Jenny![]()
Closed Thread
What is the resolution of the video?? Are you creating an NTSC or PAL disc??Every time I try to insert a Timeline (Ctrl-T) I keep getting the following error message:
Separate issue.At this point, all I want to do is start creating your most basic menu template for a DVD.
You can start off by going to Menu>Create New menu..
You can also go to the Library pallete, and drag in a new menu..
Furthermore, you can edit that same menu within Photoshop..
Good luck!!!
Open up the problem .AVI in VirtualDub. Go to File>File Information, and tell us the frame size..
Hi.
I have GSpot. I hope the information will work the same for you.
Here's a screen print:
Thanks!
Jenny
Where to start...
1)320x240 frame size isn't DVD standards..
2)Neither is the 20 FPS (Frames per second).
Obviously, this is some sort of flash card mode from the camera...
Even if you could resize and create for DVD size, the image would be degraded..Sorry..
Please don't double post. If you post in the wrong forum, let a moderator move it.
https://forum.videohelp.com/viewtopic.php?p=1490584#1490584
end of file--Adobe Encore
By koberulz in forum Authoring (DVD)Replies: 19Last Post: 18th Oct 2016, 21:21 -
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 02:09 -
Adobe Encore CS4: How to reduce output file size?
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 8th May 2010, 13:19 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 09:15
