When I import an .AVI file of 350 MB, the output (on dvd) is 2,5 GB!
I'm sure I can do something to reduce that amount of space. Preferably
to about 750 MB (instead of 2,5 GB) so I can put five of these files on
one dvd.
Can someone please tell me how? Maybe I should convert the .AVI file
in some program, before importing into Adobe Encore CS4...
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
Encore is trying to turn your highly compressed avi file into something that is DVD compliant. That means, conversion to MPEG2 and ultimately VOB files for a workable DVD structure. If you want a small file, keep it compressed as a divx or xvid .avi; but just remember that there are few DVD players (especially the older ones) that will play .avi files (although you should be able to play the videos on your PC).
You can make a data DVD, skipping Encore, and just dropping the .avi files onto disc using Imgburn or Nero. Again, they are not likely to play on most standalone, set-top DVD players in .avi form. -
Encore will fit to disc. So if you put 5 of them on , it will reduce the bitrate of each so it fits to DVD5 capacity (the quality will be terrible). Your initial test showed a 2.5GB for 1 video, because it was maxing out on bitrate for top quality. That tells you right there if you put more than 2, the bitrate will be lower that you will get bad quality
In addition , it appears as if you are starting from a low quality , compressed xvid source already. When it re-encodes to MPEG2 for DVD , you lose even more quality. I would do what filmboss suggested and find a DivX compatible DVD player.
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 14:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 09:18 -
Adobe Premiere Pro CS4 Cannot Import .mp4 File
By spike32 in forum EditingReplies: 5Last Post: 19th Jan 2010, 08:15 -
Changes in Adobe Premiere CS4 not reflected in Encore CS4 Timeline
By Funky Monk in forum Authoring (DVD)Replies: 0Last Post: 23rd Oct 2009, 06:51 -
Unlink Video and Audio Track Adobe Encore CS4
By LAM_ in forum EditingReplies: 2Last Post: 23rd Oct 2008, 15:51
