How/why is it possible that an AVI which plays perfectly on my pc, has audio out-of-sync (by about a second, from the very begining) when played on a Philips DVP-642 dvd player? I realize that this form is not for software video player questions, but there's no forum for both software and hardware playing of files. The DVP-642 plays AVI files (and dvix, xvid, mpeg4, etc.). In both cases, I am playing from the same disc. That is, I'm not playing from the hard drive on the pc, but from disc on the 642, so the file is the same.
How can it be out sync on one place and not the other?
Note: Cross-posted to video software player forum.
https://forum.videohelp.com/viewtopic.php?p=1481918
This is the right forum. It's true that sometimes files play out of synch which is probably due to the limitations of the ESS chipset inside the DVP642.
It's possible that your file uses variable bitrate (VBR) and that is causing the problems. Or perhaps the video dimensions are too large. It could be a number of things causing the problems.
When I make a file, I use xvid with a maximum of 640 width and Constant Bitrate (CBR).
If I get a file someone else made, I usually convert the audio to CBR if it was originally variable bitrate. I almost always do this with bigger files +700Mb, although VBR seems to play okay on the relatively smaller files (<200Mb).
Why don't you open the file with GSpot, and give us the following: Video bitrate, Audio bitrate, if VBR or CBR, Video dimensions.
PS video software players are things like Windows Media Player, PowerDVD, media player classic, etc., that play video files on your computer. -
You can get more info about file compatibility here: http://www.jarnot.com/twiki/bin/view/Public/DVP642LisaBsAVIGuide
Google is your Friend
Philips DVP642 vs DVP3560 Which Player plays More File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 4Last Post: 3rd Dec 2010, 14:39 -
Burned DVD with my comp = won't play, gf's comp = plays perfectly!
By DVDFuzz in forum Authoring (DVD)Replies: 13Last Post: 16th Sep 2010, 05:39 -
Remote for Philips DVP642
By Melina in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jun 2010, 21:54 -
Philips DVP642 finally died...
By Krispy Kritter in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Feb 2009, 13:06 -
PHILIPS DVP642... how do I upgrade the firmware?
By mummer43 in forum DVD & Blu-ray PlayersReplies: 39Last Post: 14th Jan 2009, 18:45
