just looking for a free program to do this, is there any such thing?
More information needed!
DVD uses MPEG-2. What do you have? You might want to look at 'What is' DVD to the upper left. <<<<<< That will tell you the DVD format. If you plan to produce a DVD, it has to adhere to that format.
Freeware. Depends again on what format you have to start with.
There are freeware encoders, freeware editors, freeware authoring programs. Cuttermaran is one freeware MPEG editor. Quenc is one MPEG freeware encoder. DVDAuthor GUI is one freeware DVD authoring program.
These are all in 'Tools'. All you have to do is look. There are also many guides to the left. <<<<<< -
Or to restate redwudz's words...
To make a "Video DVD" requires a bit more than "slap a file onto a DVD". The file must be in specific formats and so on. The link Redwudz pointed to will explain that to you.
Usually creating a video DVD has 3 steps...
First you get the files into the right format and size: MPEG2 is preferred, but MPEG1 may be acceptable. As your file is MPG, it's likely in the right format, though it may have to be resized. Most people start with AVI though, and that must be transcoded to MPEG2. This is where you do any cutting and editing as well.
Second step is assemble all the DVD-ready files into a DVD-ready image. This is also where you make various menus, add subtitles, alternate audio tracks, and that sort of misc. stuff.
Final step is to actually burn that image onto a recordable DVD.
Sounds like you're just missing the middle step. Download one of the "DVD Authoring" packages and they'll do it for you. -
https://forum.videohelp.com/viewtopic.php?t=270071
(vdub frameserving - avi/mpeg to mpeg1/2)
https://forum.videohelp.com/viewtopic.php?t=270121
(create a dvd from multiple vob clips)
Tool's used :
Vitualdub/mod (frameserver , cell time locator , audio extraction , resize)
Bbmpeg (Mpeg1/2 encoder for video frameserved by virtualdub)
Besweet (wav to ac3)
The gimp (menu's)
Batchdemux (mpeg2 demultiplexing)
Ifoedit (various function's)
Vobedit (various funtion's)
Dvdauthorgui (basic dvd authoring , motion menu's)
Pgcedit (dvd command editing , more ...)
Other's :
Folder2iso (turn dvd folder's into iso image)
Dvddecrypter or ghostburn (burning iso image's)
Dvdshrink (when authored dvd's exceed media)
There are more of course , but almost anything can be accomplished by using the above tool's .
As for frame rate conversion's , grab a copy of ulead video studio se in ebay cheap , dose a perfect job for low price .
Version 7 , under xp require's 2 updated dll's (file split problem)
Version 8 , large update download (fix's filter issue's)
Version 9 , ? ... not struck any problem's yet ... support's lpcm audio .
More guide's coming ...
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 02:26 -
How do you guys convert mpeg-4 file into dvd?
By tendra in forum Video ConversionReplies: 3Last Post: 31st Aug 2010, 01:34 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
tool to convert dvd to mpeg-1
By sumeshkri in forum DVD RippingReplies: 1Last Post: 29th Nov 2007, 03:29 -
Convert DVD to MPEG files....
By w@ntonsoup in forum Newbie / General discussionsReplies: 5Last Post: 2nd Oct 2007, 10:12
