Well i tried to convert it but 206MB became into freaking 1520MB.I don't want to lose quality and waste file size so does anyone know how to do it?Would be nice with a step by step guide.THANKS!!!!
software that i use ;
avidemux,anyvideoconverter,mediainfo,bitrateviewer.
video info ;
Format : MPEG-4
Format profile : Facebook
Codec ID : FACE
File size : 206 MiB
Duration : 19mn 0s
Overall bit rate : 1 513 Kbps
Encoded date : UTC 2010-07-28 19:13:27
Tagged date : UTC 2010-07-29 19:13:31
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Duration : 19mn 0s
Bit rate mode : Variable
Bit rate : 1 364 Kbps
Maximum bit rate : 4 673 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.062
Stream size : 185 MiB (90%)
Writing library : x264 core 72 r1232 c8edc12
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / keyint=120 / keyint_min=24 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=1364 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=1637 / vbv_bufsize=6824 / ip_ratio=1.40 / aq=1:1.00
Tagged date : UTC 2010-07-28 19:13:30
Audio
Format : AAC
Format version : Version 4
Format profile : LC
Format settings, SBR : No
Codec ID : 40
Duration : 19mn 0s
Bit rate : 150 Kbps
Maximum bit rate : 195 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 20.3 MiB (10%)
Encoded date : UTC 2010-07-28 19:13:29
It's not possible because DVD mpeg2 video requires higher bitrate/file size to get similar quality as h264/avc video.
If your dvd player supports avi divx/xvid then convert to it instead and you should be able to keep same size with similar quality. Use for example the very simple divx converter or winff, xmedia recode, etc.
Why Can't I convert the whole file in mpeg streamclip?
By alphonsecpone in forum Video ConversionReplies: 0Last Post: 5th Mar 2011, 09:24 -
How do I convert a HD MPEG-2 file to MP4?
By Newtype in forum Video ConversionReplies: 4Last Post: 2nd Feb 2010, 00:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 07:30 -
How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2?
By kiwisoup in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 22:04
