I have a .m2v (or .ts) mpeg-2 video file with interlaced frames (top and bottom fields). I want to extract top field of this video and convert it to a mpeg-1 video. Is there any tool to do this automatically ?
Height of the resulting video will be half of first video height. Extraction of top field with out any distortion (like interpolation, deinterlacing) is very important for me.
Vahid
AviSynth:
SeparateFields()
SelectEven()
http://avisynth.org/mediawiki/SeparateFields
http://avisynth.org/mediawiki/Select#SelectEven.2FSelectOdd
However, you can't just convert a field of MPEG-2 video to MPEG-1. It'll also have to be resized before being reencoded. Why are you doing this? -
Thanks manono. I'm doing this for my video content analysis project. I have source code of a MPEG-1 decoder in java and i'm using it for low level feature extraction from videos. My videos are in mpeg-2 (544*576) and must be converted to MPEG-1 (544*288). Up to my knowledge MPEG-1 standard can support high resolution videos in higher bit-rates than 1.5M. Isn't that ? Can this cause any degradation in video quality ?
Maybe it doesn't have to be resized. Maybe I should have stated it'll have to be resized for the final picture to look 'normal'. Yes, MPEG-1 video supports very high resolutions and very high bitrates.
And the act of reencoding to a lossy format always causes some quality degradation that may or may not be noticeable.
Lower field first/upper field first/progressive/de-interlaced?
By John Nada in forum EditingReplies: 7Last Post: 2nd Sep 2011, 04:12 -
Need info on field order for capturing mpeg video
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 22nd Dec 2010, 08:58 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
How to properly convert interlaced MPEG to AVI?
By lovyagin in forum Video ConversionReplies: 1Last Post: 12th Nov 2009, 06:34 -
Top Field First to Bottom Field First
By boblin2 in forum Video ConversionReplies: 0Last Post: 6th Dec 2007, 00:19
