On Sonic RecordNow!
Program use for burning CDs, and Data DVDs, said It can only hold 43xx something megabytles (xx is I forgot which numbers) instead of 4.7 which says on the DVD R
Anyone got a clue?
From Portmac, cdfreaks.comDVD capacities are usually given in billions of bytes, such as 4.7 billion bytes for a recordable disc. Computer files are measured in gigabytes. Unfortunately, both types of measurements are often labeled as "GB." So a 4.5-GB file (4.5 gigabytes) from a computer will not fit on a 4.7-GB disc (4.7 billion bytes), since the file contains 4.8 billion bytes.
The Computer sees 1GB as 1,073,741,824 bytes.
The disc manufactures see 1GB as 1,000,000,000 bytes.
So a 4.7GB DVD disc holds 4,700,000,000 bytes.
That divided by 1,073,714,824 (a real GB).
=4.37GB of real data storage.
You will need to shrink the file size to 4.37GB or less.
Sheesh...
lol...
Well Can I Burn the Files as an .ISO and take more space of the DVD? Like How CD-Rs have 200 more megabytes and you can write over it a lil bit?? -
You run greater risk of not being able to retrieve data when you try to overburn. Even more so with DVDs. Many people won't even write to the last 200 mb of a DVD because they don't trust the edges of the media.
https://forum.videohelp.com/viewtopic.php?t=291520Read my blog here.
Why is this VIDEO_TS folder 7 gigs in size?
By Hal05154 in forum Authoring (DVD)Replies: 7Last Post: 29th Mar 2012, 22:00 -
DVD shows me 750 gigs????
By lj5 in forum DVD RippingReplies: 10Last Post: 5th Feb 2010, 03:02 -
Is this Normal with 6 gigs of memory?
By ineedhelp007 in forum ComputerReplies: 13Last Post: 11th Jan 2008, 17:59 -
when captured avi goes over 4 gigs nothing recognizes it ?
By 99teggsr in forum Capturing and VCRReplies: 11Last Post: 28th Dec 2007, 22:00 -
How do I go about svaing 75 gigs of data?
By jehosafats in forum ComputerReplies: 4Last Post: 8th Oct 2007, 16:11
