So do you always leave some space so that you don't burn on the edges of blank dvds???
I don't always buy name brand discs so I'm trying to remember to encode to 4gb instead of the single layer limit. Though of course I don't always.
Results 1 to 11 of 11
i always use high quality japanese made media.. so i have no problems burning to the maximum capacity of the disc..
i learned my lesson many years ago about cheap dvd-r media..
i've got movies from 5 years ago that are 4.37gb and i can still make copies of them without a problem.
although when backing up movies, i always keep the main menu, because it is a backup i'm aiming for the highest video quality..
i use clonedvd2 to transcode my movies now, and i usually remove extras & additional audio tracks to get 100% video quality or the highest video quality available.. sometimes that will leave me at something like 4.1gb or 4.2gb..
Whatever it takes. If it's too much, I add more discs. Or I jump to a DL.
I've always burned the full 4.37GB capacity and always used good media. I started off using Riteks, Now use Taiyo Yuden discs. Never had a problem so far.
My upper limit is 4.2 GB. Never a byte above.
/Mats -
Do you always burn under the max capacity of a disc?
Kinda hard to burn over the max capacity.
4475-4480 MB for me. -
I suppose I could have phrased it "do you burn under the limit of the disc" but it seemed like everyone understoodOriginally Posted by manono
And actually at least for cdr's you can overburn. I've never bothered to find out if you can overburn a dvdr. The point was asking if people just encode to the maximum of the disc and not worry about possible read errors at the edges
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
y'know, you can overburn dvd-r's?Originally Posted by manono
i burn whatever i need as far as the disc capasity goes, i generally dont do things like throw in dummy files and such to push data towards the outer edge of the disc, and if a disc happens to push the limits of the dvdr, then so be it.....i just try to keep good care of my discs....
Optical Disc Storage Capacity
By Frank-0-Video in forum MediaReplies: 2Last Post: 8th Jun 2011, 11:57 -
What is the LARGEST capacity disc I can buy?
By sarainelkins in forum MediaReplies: 17Last Post: 20th Mar 2011, 23:43 -
What is max bitrate and max channels supported by PCM audio format?
By Bonie81 in forum Newbie / General discussionsReplies: 10Last Post: 18th May 2010, 23:35 -
Max Hard Disc Size on PS3?
By SCDVD in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2008, 04:11 -
after buring DL+R disc, my burn can't burn -R disc, please help!
By princejoe18 in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Sep 2007, 07:44
And I don't think -200Mb is going to be missed.
