Is there any way to cut real media movie files using virtualdubmod or any other program?
Results 1 to 11 of 11
you maybe could use avisynth, real alterantive and import the avisynth script in virtualdubmod but you must reencode to another video format.
https://forum.videohelp.com/viewtopic.php?t=284288 -
Is there any other way? I have tried using avisyth before but have no idea what to start and what to do.
Seems some people are allergic to AVISynth or something.
The script will take 2 lines at most, provided that Real Alternative is already installed. One of the lines is a comment header.
Obviously, replace fps with the actual fps value.#ASYNTHER DirectShow_NTSC
DirectShowSource("C:\My Documents\myvideo.rmvb", fps=29.97, convertfps=true)
As already stated, VDub does NOT write to RM format, so you have to save it as AVI or one of the formats that it DOES output to. Then maybe rencode as RM. -
Is it ok if I use wordpad instead of notepad? And how would I determine the frame rate of my file?
If you just want a simple cut, remedit. Also might check out the activity at the helix site -- last I checked there were a couple of front ends for the open source producer, including some cutting joining, but it's been a while. Any way you do it however, unless you convert to avi all you can do is go to the Real version of the closest I frame.
Ok, I just got it to work but when I cut only a tiny portion of the file that should be about 30 mb, the final avi file size says that it will be 1360 mb. How do I lower the file size to the first value without losing any quality? I've tried compressing with xvid, but the files are still too large.
Use the slide bar at the bottom of VDub to pick the portion you want to keep, encode until you get to a stop point, and check if the output is okay.
Remember you need to pick Full Processing, and pick a compression codec when saving the AVI, which starts the actual job. -
But both of those ways make the file bigger than it actually should be. For example I cut out 5 parts of the clip, which is only half the total running time of the clip. However, all 5 clips are 100 mb greater than the original file when compressing at 100% with the xvid codec in both full processing and fast recompression mode.
If it helps...
You have a file encoded to real, and using V/Dub you're converting the video to an uncompressed format, then re-compressing it. The size of the file depends on how much you recompress it, as much as it depends on the length. If you don't want to decompress, edit, re-compress, maybe the best thing to do is use something like rmedit, which will simply copy a part of your original file to a new file without changing anything.
Otherwise, if you want the level of compression to stay roughly the same, you have to adjust the settings for the encoder your using, use another codec, or frame serve from V/Dub to a prog. using the Real codecs (something like realanime on ft page here at videohelp). -
I've tried google searches for both rmedit and rmtools but can't seem to find any download sites. Can you provide a link for me?
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 03:53 -
Can Real Media files (.rm, .rmvb) be demuxed?
By Huh...What? in forum Video ConversionReplies: 5Last Post: 4th Mar 2010, 11:06 -
Windows Movie Maker and Real Media
By Xarzu in forum Video ConversionReplies: 1Last Post: 28th Nov 2009, 19:37 -
A simple trimmer for real media files
By kutchbhi in forum Newbie / General discussionsReplies: 7Last Post: 22nd Sep 2009, 08:29 -
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 10:45
