ok i have bunch of raw avis with 16:9 aspect ratio (confirmed by Gspot)
when im converting them to wmv, without any resizing or so, the outputed wmv plays in 4:3
when i check the wmv with gspot, it doesnt show any info about the aspect ratio (why is that?)
so, how to properly convert my AVIs to wmv and keep the default aspect ratio of 16:9?
p.s. the software im using is videocharge
	Try using the free Windows Media Encoder - it can definitely output 16:9 (you specify it in the profile) - and see if it helps.
 AVI file headers don't contain aspect ratio information per se. Aspect ratios are guess from the image definition in the header - i.e., the equivalent of a bitmap header is stored in the AVI file that simply tells the software using it what size the image is.
 If videocharge doesn't support 16:9 encoding, you'll have to use another program such as WME.John Miller
	WME is scriptable and can even be embedded into other applications.
 I can't vouch for this but here's an article that claims to do batch processing:
 http://www.tech-recipes.com/rx/2699/windows_media_encoder_9_batch_file_encoding_videos...avi_asf_to_wmv
	If you search around MS's site there's a download for an example script for batch processing.
  Impossible to copy dvd?By tomkat in forum DVD RippingReplies: 21Last Post: 20th Mar 2010, 08:10
  AVI to WMVBy fzf5bl in forum MacReplies: 1Last Post: 22nd Jan 2009, 13:42
  Converting to any format is impossible.By pownager704 in forum Video ConversionReplies: 3Last Post: 19th Apr 2008, 11:07
  Impossible to capture streamBy hauk in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2007, 02:12
  wmv to aviBy d_carter in forum DVD RippingReplies: 5Last Post: 23rd May 2007, 23:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
