Im following a guide for vdub and it says that I need to select yuy2 as the colourspace of my input file but vdub2 doesnt have a colour depth option within the video tab. it does have a decompression format option though. Should I select yuy2 here?
[Attachment 83533 - Click to enlarge]
If the source colorspace is YUV420 (YV12) you shouldn't need to convert it, although your screenshot indicates the source is YUV422, which is the planar version of YUY2. It should be safe to just select YUY2 as the compression format (click Configure).
Edit: After a quick test the simplest way to do it seems to be to select Fast Re-compress from the video menu (it means VirtualDub won't do anyconverting, but it doesn't need to as the source is already YUV422), and select Auto Detect under "Video/Decode Format". Select YUY2 as the compression format for Lagarith. The "Pixel Format" button should be greyed out when Fast Re-compress is selected.
[Attachment 83536 - Click to enlarge]
The output might be YV16 (YUV422), but you can convert between YUY2 and YV16 losslessly as they're the same thing aside from the way the pixels are stored in memory, so it doesn't matter.
http://avisynth.nl/index.php/Convert
http://avisynth.nl/index.php/YUY2Last edited by hello_hello; 17th Nov 2024 at 14:19.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
I edited my previous post with some more info after experimenting a little, although it doesn't matter....
Converting AVI to MP4 in virtualdub2?
By Leanoric in forum Video ConversionReplies: 12Last Post: 4th Feb 2023, 12:51 -
Dropped frames after converting interlaced to progressive with VirtualDub2
By Hajker in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2023, 06:09 -
Which is best YULS, FFV1, MSU, Lagarith or Huffyuv for compressing VHS?
By bigbadben in forum Capturing and VCRReplies: 6Last Post: 13th Oct 2020, 17:18 -
Virtualdub2 and FFmpeg: How do I convert this code to Virtualdub2?
By Guernsey in forum Newbie / General discussionsReplies: 0Last Post: 8th Sep 2020, 04:25 -
Any Consumer-Level Video Editor That Supports Huffyuv or Lagarith Codecs?
By Avagadro1 in forum EditingReplies: 18Last Post: 17th Aug 2020, 21:19
