Hello
Would anyone know of any free (unlimited) online audio silence remover tools designed to detect and eliminate unwanted silences in audio recordings?
If you can accept offline (i.e. local on your computer) tool then ffmpeg ( https://ffmpeg.org/ffmpeg-filters.html#silenceremove ) can do this for you.
foobar2000 has a free offline silence remover. You don't have to edit the audio to remove silence on playback if you'd prefer to remove it on the fly. The "skip silence" DSP can be added to the playback chain, or it can be added to the conversion chain so you can convert and remove silence in one step. It doesn't have a lot of options but it does the job.
[Attachment 83057 - Click to enlarge]Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
looking for a great audio tool to convert my audio files
By bballnut in forum AudioReplies: 4Last Post: 25th Nov 2023, 01:17 -
MSU Subtitle Remover Stopped working in VirtualDub2
By deepfrayder in forum EditingReplies: 12Last Post: 12th Nov 2022, 17:26 -
easy way to join a series of mp3 files and insert a 4 sec silence
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 22nd Oct 2022, 12:28 -
Movie Profanity Remover
By inieuwoudt1 in forum EditingReplies: 64Last Post: 22nd May 2022, 21:12 -
dotcrawl remover for avisynth+
By FelipeArchives in forum RestorationReplies: 33Last Post: 11th Jun 2021, 13:49
