  1. RGBColor - A VapourSynth function for specifying color
    Even though the default color is "black" for VapourSynth's AddBorders & BlankClip functions, the added borders are always full range (for 8 bit video the black level is 0 rather than 16 as it should be for limited range video). The RGBColor function will ensure the black level is correct. YUV and RGB are both supported at any bitdepth (except for half float).
    RGBColor 2025-03-25.zip
    import vapoursynth as vs
    core = vs.core
    import RGBColor as rgb
    Specifying a border color for the AddBorders function
    Adding black borders
    clip = core.ffms2.Source("Video.mkv")
    clip = core.std.AddBorders(clip, 20,20,0,0, color=rgb.RGBColor(clip))
    Adding dark blue borders
    clip = core.std.AddBorders(clip, 20,20,0,0, color=rgb.RGBColor(clip, color="darkblue"))
    Specifying the color of a blank clip with the same properties as a previous clip
    A blank clip with black frames
    BClip = core.std.BlankClip(clip, color=rgb.RGBColor(clip))
    A blank clip with red frames
    BClip = core.std.BlankClip(clip, color=rgb.RGBColor(clip, color="red"))
    Specifying the color of a blank clip when no previous clip exists
    BClip = core.std.BlankClip(format=vs.YUV420P8)
    BClip = core.std.BlankClip(BClip, color=rgb.RGBColor(BClip))
    BClip = core.std.BlankClip(BClip, color=rgb.RGBColor(BClip, color="red"))
  2. Is it compatible to the version from last year? (so can I replace the old version or so I need to adjust scripts where I used the old version?)
  3. Yes it's compatible. The main difference is this version specifies the color range correctly when determining the color.
    I hadn't realised the VapourSynth frame property uses 0 for full range and 1 for limited, while the resizers use 0 for limited and 1 for full, so this version takes any specified "range", or the _ColorRange value in frame properties, and converts it to a string.
    The ColorClip line near the end now uses
    resize.Point(range_s="limited")
    instead of
    resize.Point(range=1)
    which would have meant it was specifying a full range value for limited range video.
    The original version required the user to specify a color. This version defaults to "black".
    And for some reason the original didn't include "lightgray" as a color, only "lightgrey". It should've included both (as the same color).
  4. Thanks for the info.
    Aug 2018
    Wrocław
    Avisynth too.
  6. It wasn't that I'd mixed up the value in frame properties, but I'd either forgotten or never knew that the VapourSynth resizers do it backwards.
    Something like the following will cause VapourSynth to write a value of 1 for _ColorRange in frame properties because 0 is limited range for the resizers, while 1 is limited range in frame properties.
    clip = core.resize.Spline36(clip, 640,480, range=0)
    The safest way to do it for the resizers, especially if you want to change the range, is to use a string rather than 0 or 1, at least for me because I'm easily confused.
    clip = core.resize.Spline36(clip, 640,480, range_in_s="full", range_s="limited")
  7. There's a link for a new version dated 2025-03-25 in the opening post.
    The functionality hasn't changed at all but I think I changed the syntax a little at some stage, however it was a while ago and I actually can't remember.
