  1. Hi. In the video I'm editing, there's a terrible slo-mo scene where the frames are aaaaabbbbbccccc etc. I can put it back to normal speed with
    trim(0,0)++trim(5,5)++trim(10,10) etc
    but I'd be there all day. Is there a way to script "start at frame 1234 then use every fifth frame"?
    Many thanks.
  2. SelectEvery is part of Avisynth and does what you want.
    SelectEvery(clip, 5, 0)
    chunks the source in groups of 5 and just keeps the first of each group.
  3. SelectEvery(5, 2) would mean for each group of 5 frames you're keeping the third one (as Avisynth starts counting at zero).
    Assuming it's a section in the middle of the video, say from frames 1234 to 2233.
    A = last
    B = A.Trim(0, 1233)
    C = A.Trim(1234, 2233).SelectEvery(5, 0).AssumeFPS(24) # or whatever the original frame rate is
    D = A.Trim(2234, 0)
    B + C + D
    or select 1 frame from each group of 5 starting at frame zero.
    A = last
    B = A.Trim(0, 1233)
    C = A.Trim(1234, 2233).SelectRangeEvery(5, 1, 0)
    D = A.Trim(2234, 0)
    B + C + D
    Edit: Selur beat me to it....
  4. Brilliant, lads. Thanks a lot.
