  1. Hi,
    I have a very rare DVD I would like to backup properly processed, below is the MediaInfo section relevant to the video. Could anyone tell me what processing I should do to it? I would like to use ffmpeg or handbrake (I'm on linux). Should I be using a deinterlace filter that changes the frame rate? I did some googling, and basically every thread contradicts itself.
    Here is a sample https://workupload.com/file/XShefM3kyXd
    Thank you!
    Video
    ID in the original source medium : 224 (0xE0)
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings : CustomMatrix / BVOP
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=15
    Format settings, picture structure : Frame
    Codec ID : V_MPEG2
    Codec ID/Info : MPEG 1 or 2 Video
    Duration : 22 min 8 s
    Bit rate mode : Constant
    Bit rate : 8 000 kb/s
    Width : 720 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.772
    Time code of first frame : 10:00:07;11
    Time code source : Group of pictures header
    GOP, Open/Closed : Closed
    Stream size : 1.24 GiB (98%)
    Language : English
    Default : No
    Forced : No
    Original source medium : DVD-Video
  2. It appears to be telecined but it's a bit of a disaster for some reason. In theory all you should need to do is enable Handbrake's detelecine filter and nothing else, and set the output to a constant frame rate of 23.976. There's a lot of aliasing and shimmering going on though. I had a crack at it using Avisynth but that wasn't much more successful.
  3. Originally Posted by hello_hello View Post
    thank you so much for taking the time to look through it.
    Do these look right to you? --detelecine --rate 23.976 --cfr
    While encoding:
    + filters
    [12:33:23] + Detelecine (pullup) (skip-left=1: skip-right=1: skip-top=4: skip-bottom=4: plane=0)
    [12:33:23] + Framerate Shaper (mode=1:rate=27000000/1126125)
    [12:33:23] + frame rate: 29.970 fps -> constant 23.976 fps
    Thanks!
  4. In ffmpeg try
    ffmpeg -i "output.mkv" -an -c:v libx264 -preset slow -crf 18 -pix_fmt yuv420p -vf fps=30000/1001,fieldmatch,yadif=deint=interlaced,decimate "IVTC_.mp4"
  5. Originally Posted by Sharc View Post
    In ffmpeg try
    Thank you!! Giving it a try as we speak. is this output normal?
    [Parsed_fieldmatch_1 @ 0x557130774180] Frame #1539 at 51.3513 is still interlaced dup=1 drop=0 speed=5.51x
    [Parsed_fieldmatch_1 @ 0x557130774180] Frame #3087 at 103.003 is still interlaced dup=1 drop=0 speed=5.27x
    [Parsed_fieldmatch_1 @ 0x557130774180] Frame #3088 at 103.036 is still interlaced
    [Parsed_fieldmatch_1 @ 0x557130774180] Frame #3148 at 105.038 is still interlaced dup=1 drop=0 speed=5.23x
    [Parsed_fieldmatch_1 @ 0x557130774180] Frame #3149 at 105.072 is still interlaced
  6. Originally Posted by pstnnn View Post
    In ffmpeg try
    The source has few hiccups I think. The result should nevertheless be "ok" I would assume. Check it.
    For more info about the options and tweaks of fieldmatching see the ffmpeg doc:
    https://ffmpeg.org/ffmpeg-filters.html#fieldmatch
  7. Originally Posted by Sharc View Post
    In ffmpeg try
    thanks mate, i really appreciate the help
