Hi, does anyone know why an MP4 file I have of a film at around 7GB in size won't fit onto an external HDD which has around 50GB of available space left on it?. Does this mean the file is much bigger than it is? (I've checked the file in MediaInfo and it reads as it should at 7.92GB). I copied the file from an internal HDD when I removed it some months back, at first on my other external HDD and it copied the file over without any problems onto that one, but for some reason it can't transfer the file onto my other HDD.
It's possibly formatted as fat32, which has a file size limit of 4GB. Older versions of Windows, and possibly newer versions too, mislead you by telling you there's not enough room on the drive.
If that's the reason, reformatting the drive using the NTFS file system will fix the problem, although if you're using the drive with a non-PC device, make sure it can read an NTFS drive.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
because probably your external HDD is FAT32 formatted which has limit of 4gb filesHi, does anyone know why an MP4 file I have of a film at around 7GB in size won't fit onto an external HDD which has around 50GB of available space left on it?. Does this mean the file is much bigger than it is? (I've checked the file in MediaInfo and it reads as it should at 7.92GB). I copied the file from an internal HDD when I removed it some months back, at first on my other external HDD and it copied the file over without any problems onto that one, but for some reason it can't transfer the file onto my other HDD.
External HDD enclosure issue
By techmot in forum ComputerReplies: 16Last Post: 2nd Aug 2023, 16:30 -
HDD Ventilated External Casing
By tugatomsk in forum ComputerReplies: 6Last Post: 11th Aug 2022, 12:48 -
Data Recovery on USB external HDD?
By Gurd99 in forum ComputerReplies: 3Last Post: 5th Dec 2020, 21:14 -
Help please!! How to power my external HDD connected to TV
By thegeeman in forum Newbie / General discussionsReplies: 27Last Post: 7th Jul 2020, 13:12 -
Recording to an external HDD from my Panasonic TX-58DX750B Viera TV
By Gil T Remnant in forum DVB / IPTVReplies: 4Last Post: 29th Mar 2020, 04:40
