Hello, I have a show that has 23.976p and 29.97p sections throughout the video and I'd like to preserve the 29.97 sections without using something like TIVTC to decimate those sections. Instead, I'd like to follow what the Italian Cowboy Bebop anime Blu-ray did with it's encode and add 3:2 soft pulldown flags for those specific sections and allowing it to change frame rate to 29.97. Is this something that can be done in x264 while being Blu-ray compliant or do I need to use another encoder? The closest I've gotten is to my goal is deinterlacing the 29.97i source to 29.97p (despite the 29.97 sections are actually PsF) and TIVTC the same source and cutting them together in a 29.97 timeline and encoding it with the hard pulldown.
x264 supports soft pulldown. For 3-2 pulldown try
--pulldown 32 --pic-struct --fake-interlaced
http://www.chaneru.com/Roku/HLS/X264_Settings.htmLast edited by Sharc; 18th Apr 2023 at 02:03.
But can I use that for one section of the video and then turn off the flag for the 29.97 part of the source?
Variable frame rate? Of course it won't be Bluray compliant so if that's a deal-breaker don't keep reading, but my Bluray player happily plays VFR video via it's USB input. I rarely use it to play Bluray compliant video of any sort.
TIVTC has a 2 pass mode. It can IVTC the film sections to 23.976fps and de-interlace the video sections to 29.97fps (or just keep them progressive). It'll output a timecodes file which can either be used for muxing, or added to the x264 command line, in which case it'll encode in variable frame rate mode.
--tcfile-in "D:\Video Timecodes.txt"
The script output would be at the average frame rate, as Avisynth needs a constant frame rate, but x264 ignores the input frame rate when it's given a timecodes file and uses it instead.
There's example scripts in the TIVTC zip file. The first pass is run as an analysis pass and creates the metrics files. As long as you disable any filtering following TFM/TDecimate in the script, it's fairly fast. The second pass is the encoding pass and it also creates the timecodes file as soon as the second pass script is opened.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
N_m3u8DL-RE_Beta_win-x64 flags on Virustotal
By bamboobali in forum Video Streaming DownloadingReplies: 3Last Post: 14th Apr 2023, 05:22 -
Software for Correcting Headers/Flags
By MisterF in forum Video ConversionReplies: 1Last Post: 23rd Jul 2020, 19:27 -
Can I get a 30p file with pulldown flags back to 24p without re-encoding?
By bergqvistjl in forum DVD RippingReplies: 5Last Post: 7th Jul 2019, 21:06 -
Setting fake-interlace flags using MultiAVCHD
By Ravanosh in forum Authoring (Blu-ray)Replies: 0Last Post: 18th Mar 2019, 10:14 -
Any way to edit a BD sup file and set forced flags?
By JackBauer in forum SubtitleReplies: 6Last Post: 1st Sep 2018, 10:02
