  1. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    I ripped 'Pans Labyrinth' a few years back, a copy from the local library. It is now long gone (deleted).
    I recently bought a copy at a thrift store (2 disk set). Main disk appears pristine. Plays OK in dvd player but will not rip. I had much grief ripping the 1st time, finally ript it, dont remember what I did.
    Same issue with this new disk, this time, no ripping. Tried anydvd, new & old versions. Nada.
    'shrink', nada, dvdsmith, nada.
    The best I can do is: all the *.ifo files get ripped, but nothing else.
    Any suggestions??
    -corne-
    yep, Im still around!
    Yes, no, maybe, I don't know, Can you repeat the question?
    Aug 2006
    If you are OK with just mkv files instead of a complete set of DVD files and folders, you could try MakeMKV.
  3. Do you have access to a second DVD drive?
    Years ago when I was buying and ripping lots of discs regularly I had three of them. It wasn't unusual for one, even though as a general rule they all worked well, to have problems reading a particular disc while another drive didn't. On the odd occasion, when a disc was badly manufactured or scratched or something.... it'd take the combined efforts of all three drives to rip the entire disc successfully.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    It's available as Blu ray from Amazon Australia https://www.amazon.com.au/PANS-LABYRINTH-BEYOND-GENRE-BLU-RAY/dp/B09R846QFB
  5. Anonymous84
    Guest
  6. ½ way to Rigel 7 cornemuse's Avatar
    Mar 2014
    Cyber Dystopia
    Tried multiple (2 anyways!) dvd drives
    edit: No BluRays no MKV*
    Aug 2006
    Perhaps DVDFab would work.
