Results 1 to 12 of 12
  1. I want to Bob deinterlace a DVD without changing the frame rate. I'm not sure which of the two scripts I've made is the correct one:
    LoadPlugin("C:\DGMPGDec\DGDecode.dll")
    MPEG2Source("D:\Project\IEEE-1180_Reference.d2v")
    SeparateFields()
    Bob()
    SelectEven()
    or
    Bob()
    SelectEven()
    Do I need to use 'SeparateFields()', or should I remove it?
    Which of the two scripts is the correct one for deinterlacing without doubling the frame-rate?
    Aug 2013
    Central Germany
    Do not use SeparateFields(). Bob() can handle "FrameBased" interlaced video.
    You will just lose details by replacing one half of the video lines with interpolated averages this way. Using a smarter deinterlacer which can restore the missing lines of a field using information from previous and following fields in motion estimation (like QTGMC or TDeint) should produce a more detailed result. So your desired method may only be suitable as academic half-bad example in comparison.
  3. QTGMC and SelectEven()
  4. Originally Posted by LigH.de View Post
    Thanks.
  5. Originally Posted by s-mp View Post
    I tried QTGMC and it is crap. On all presets. It produces plastic looking videos. Just like Yadif.
    I wouldn't touch it with a ten-foot pole. It's just a bunch of filters jumbled together without taking into account the transparency and noise/grain of the source.
    Stay away from it.
    Mar 2008
    Stay away from it.
    Here some more for you to try.
    http://avisynth.nl/index.php/External_filters#Deinterlacing
    What is your source? TV show shot on Video ?
  7. Originally Posted by davexnet View Post
    Stay away from it.
    It's a DVD collection of '80s music videos (Phil Collins, Duran Duran, etc...).
  8. Originally Posted by orion44 View Post
    Stay away from it.
    Transparency?
    Why keep the original frame rate? Most players support 50/60p these days, especially for standard definition, and if you watch the interlaced video on a progressive display, that's how the player or TV will/should be de-interlacing it.
    QTGMC has plenty of options. There's options for adding back noise/grain after de-interlacing, and there's even semi-lossless modes and a lossless mode.
    Lossless mode leaves the original scanlines untouched.
    Yadif(mode=1) also leaves the original scanlines untouched.
    Try this. The output should be completely grey.
    A = last
    B = A.SeparateFields()
    C = B.SelectEven()
    D = B.SelectOdd()
    Yadif(mode=1)
    SelectEven()
    E = last
    F = E.SeparateFields()
    G = F.SelectEven()
    H = F.SelectOdd()
    Subtract(C, G)
    # Subtract(D, H)  # not completely grey
    If you like Bob(), I guess you must like lots of shimmering and aliasing added to the noise and transparency.
  9. Member Skiller's Avatar
    Oct 2013
    Germany
    So the presets don't fit your needs (they don't for me either, most of the time) but that doesn't mean QTGMC is crap.
    Yes, the defaults sometimes denoise quite a bit, many people like it, I don't. But luckily you can tweak beyond the presets.
    I recommend you give this set of parameters a try. For keeping the original look of grainy 80's music videos some of these are essential.
    QTGMC(TR0=2, TR1=2, TR2=1, Rep0=1, Rep1=0, Rep2=4,
    \ ThSCD1=300, ThSCD2=110,
    \ SourceMatch=3, Lossless=2, Sharpness=0.1, Sbb=0,
    \ NoiseProcess=2, GrainRestore=0.0, NoiseRestore=0.4, NoisePreset="slow",
    \ StabilizeNoise=false, NoiseTR=0, NoiseDeint="bob")
    You can increase NoiseRestore if you need more noise but note that you can overamplify the noise easily.
    Now this doesn't look like plastic, what do you think?
  10. I'm happy with the results produced by Bob() and FieldDeinterlace (Decomb). I'll give QTGMC one more chance and try the above settings when I have more time.
    I just wish the guy who created QTGMC would have assumed that not all its users will have a PhD in engineering and digital signal processing or whatnot.
  11. Member Skiller's Avatar
    Oct 2013
    Germany
    QTGMC wasn't created by one guy, it evolved over the course of years and various people worked on it (Didée wrote the original TempGaussMC core back in 2008, Vit and real.finder added many features and optimizations).
    And frankly, the usage is well documented. It's all there.
  12. I tried QTGMC and it is crap. On all presets. It produces plastic looking videos. Just like Yadif.
    You know you can just disable denoising
