I two mono tracks for actors track that I want to pan left and right. Most software does it with "pan pots", increasing the sound level through some "pan law".
In real life, if a sound comes from 1.30pm on a clock face (45 degrees to my right), it will reach my right ear slightly earlier than my left ear. I am looking for software that implements this time delay when panning. Does it exist?
Logically though, if you pan something right so it's coming from the right speaker and you're standing between them, the sound will reach your right ear before your left one anyway.
I imagine applying a delay would result in phase cancellation unless the sound in question is panned completely left or right. If you had the same sound in both channels and they were panned centre and you applied a slight delay to one of them, it'd phase cancel with the other and produce a "phasing" effect. The same thing would happen if you applied a delay to one channel while panning a mono source, unless it's completely panned left or right, in which case I'm not sure what the benefit would be to applying a delay.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Yes, that's true and applies to all cases except headphones.Logically though, if you pan something right so it's coming from the right speaker and you're standing between them, the sound will reach your right ear before your left one anyway.
Yes, indeed. Today I learned about this phasing effect. I tested it with 5 and 10 ms; it does sound weird indeed. Furthermore, sometimes my soundtracks play on a mono speaker.I imagine applying a delay would result in phase cancellation unless the sound in question is panned completely left or right. If you had the same sound in both channels and they were panned centre and you applied a slight delay to one of them, it'd phase cancel with the other and produce a "phasing" effect.
So it's best to pan left and right as usual, leave the tracks as they are to avoid the phasing effect, and rely on left and right speaker to convey left and right panning. -
I made an offline processing software for this (called "Audition") in 1987, then worked up better again in 1992, and then tried to get it marketed in 95-96. The only company that responded to me then was Crystal River Engineering in SF, Cal. But I was so poor at the time I didn't take them up on their offer to meet in Cal.
Year and a half later, they (now Aureal cuz they got bought out) come up with a $$ plug-in for ProTools that graphically maps it in real-time and uses the DSP to process online in realtime. They were probably working along similar lines given their history, but the gui and operation look an AWFUL LOT like my prototype. Not calling out, but I'm just saying...
Anyway, there are 3D Audio & HRTF type plugins out there. You just have to know the terms to search for them.
Scott -
You want to use either headphones as output, or speakers with Inter-aural Crosstalk removal (e.g. Carver Sonic Holography, Polk SDA speakers, others). Otherwise the effort of doing Inter-aural time/phase differencing is wasted, as was mentioned.
Scott -
Thanks Scott! I read about the Head-Related Transfer Function and it sounds fascinating. I'll try this type of techniques when I have control of the sound system, which I don't for now (the videos are online).
How to download a ts stream and with a video/audio time delay?
By BosseB in forum Video Streaming DownloadingReplies: 8Last Post: 10th Mar 2021, 19:21 -
Audio Delay
By m00511 in forum Newbie / General discussionsReplies: 12Last Post: 1st Sep 2018, 23:48 -
audio/interleaving/delay audio in Virtualdub2/Filtermod & filter weirdness
By davexnet in forum Video ConversionReplies: 2Last Post: 19th Apr 2018, 12:28 -
joined ts video has 3-second delay if jumping to different time
By cpliu in forum Video ConversionReplies: 6Last Post: 21st Jan 2018, 08:15 -
ffmpeg audio delay - how to get the video to start before the audio ?
By Selur in forum Newbie / General discussionsReplies: 6Last Post: 13th Mar 2017, 15:30
