Thank you again Hello_Hello and Davexnet for help , i will leave it with this minor jerkys , it's not so bad , i can survive with this...anyway it's look better than dvd.
Results 31 to 34 of 34
Just in case then, use TDecimate this way.
TDecimate(Hybrid=1)
The output will still be 23.976fps.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Sometimes you have irregular pulldown patterns (not simple 3:2) and TDecimate(Cycle=10, CycleR=2) will work better than the default (Cycle=5, CycleR=1). Or even Cycle=15, CycleR=3) or more.
You will find some shots were sped up or slowed down so they can't be decimated to 23.976 fps smoothly. Or those shots may be 30p or 30i. There are so many possibilities. Sometimes I just give up and encode at 60p after QTGMC() -- that will give the same smoothness as watching the original DVD on an analog SD TV. -
I tried some tests with hybrid ( i use decomb telecide+decimate because i don't have ghosting )but with TIVTC ( Tfm+Tdecimate ) ghosting is back and with hybrid=1 it's the same . With cycle=10 , cycle=15 same thing , only encode at 60p seems to help for smoothnes
In this case i guess i don't have to use decimate and convert to 60p , but witch is the right way to do that ( hybrid, for test i use FrameRateConverter) ?
TIVTC is a poor deinterlacer?
By killerteengohan in forum RestorationReplies: 9Last Post: 17th Oct 2019, 15:33 -
Quick question on TIVTC's Tdecimate
By attackworld in forum Newbie / General discussionsReplies: 4Last Post: 11th Mar 2019, 15:05 -
Interlacing after TIVTC
By Vitality in forum RestorationReplies: 12Last Post: 26th Nov 2018, 15:01 -
Need help using TIVTC
By Joycon in forum Newbie / General discussionsReplies: 1Last Post: 9th Sep 2018, 07:53 -
Deinterlacing/TIVTC causing jittery video?
By killerteengohan in forum RestorationReplies: 56Last Post: 24th Aug 2018, 06:35
