    is there a way to diable chapters in a movie, or a button to play the next movie in a folder? the button just plays the next chapter and I have to move the slider along to the end and then press it to make it jump to the next movie
    stay safe
  2. Not that I know of, but you can use keyboard shortcuts or set a mouse action.
    The defaults for skipping between chapters are Page Down and Page Up, and they work like the back/forward buttons. If there's no chapters and the option under Tweaks is enabled, they skip to the previous/next file.
    CTRL + Page Down and CTRL + Page Up ignore the chapters and jump between files, which I've changed to Alt + Left Arrow and Alt + Right Arrow, but if you prefer you can set a mouse action.
    Look for the Next, Previous, Next File and Previous File choices under Options/Player/Keys. To change a keyboard shortcut you need to click on the appropriate space in the Keys column to select it, then press the keys you wish to use as the shortcut.
    great stuff that worked. ill insgtall the gom player as well. they have a specific feature I like which is how much to jump forward or backwards. I can tweak it for 2 seconds. I couldnt find it in mpc
    thanks so much.
    mpc-hc Options O > Player > Keys > "Jump"
    O > Tweaks > Jump distances for the 3 values
