I have a progressive 29.97fps 1920x1080p video that originally was PAL 25fps (pro-recorded concert in France). Someone inserted frames to get 29.97fps.
How can I find and remove the duplicate frames to get it back to 25fps without affecting audio-video sync?
I opened it in Virtualdub2 and verified there is no combing, just periodic duplicate frames. As I want to use SVPFlow (via Avisynth) to get a smooth 50fps, I need to get it back to 25fps first. I have demuxed the file into .mp2 and .avc files but don't know how to process this. I searched and found FDecimate() and the page describing the issues at hand. Is there a better way? Any help would be much appreciated by me.
Here's a short sample (11MB):
lamsf-29.97fps-clip.mkv
https://mega.nz/file/E4dhwKjC#nuHNw4tBXnZykOvkt9K-EJY0QeCdQUCstXIWjbfV6gI
FDecimate(rate=25,threshold=2,protect=true) gets me to 25fps, but there are still dups. I'm trying to change the dups to interpolated frames with InterpolateDoubles (part of the FrameRateConverter plugin). So far no luck. I'm using it like so: InterpolateDoubles(Thr=0.1,Preset="slowest",BlkSiz e=16)
The Thr value seems to have no effect. I'm using "slowest" otherwise I get artifacts (with FrameRateConverter...I now use SVPFlow as it's much faster).
Any other dup to interpolated frame plugins I should be looking at? -
It's not uncommon for PAL to be converted to NTSC by slowing it down to 24.975fps and repeating fields, or in this case, repeating every fifth frame.
For some reason the old version of Lsmash I'm using on XP decodes at a frame rate of 29.9717fps, but FFMS2 seems to be getting it right.
If you want 25fps (I wouldn't bother) you'll need to follow TDecimate with AssumeFPS(25) to speed it up again, and re-encode the audio to match. You can use the AudioSpeed function in my signature for that.Code:LoadPlugin("C:\Program Files\MeGUI\tools\ffms\ffms2.dll") FFVideoSource("E:\lamsf-29.97fps-clip.mkv", threads=1) TDecimate(Cycle=6) # from the TIVTC plugin
Here's a quick SD re-encode (edit: forgot to add the audio).Last edited by hello_hello; 16th Dec 2020 at 10:32.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
LWlibavVideoSource returned a 29.97 fps clip and TDecimate converted to 24.975 fps with no duplicates or drops:
Converting that to 25 fps with ChangeFPS will give one duplicate every 40 seconds.Code:LWLibavVideoSource("lamsf-29.97fps-clip.mkv", cache=false, prefer_hw=2) TDecimate(Cycle=6, CycleR=1) -
TDecimate(Cycle=6, CycleR=1) works well.
Thank you everyone for helping!
Blended Frames during QTGMC - 25fps assuming bad authoring to PAL format?
By LaserBones in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2020, 07:33 -
Converting a vhs pal 25fps video into bluray 23.967 (audio & video)
By theundertaker180 in forum AudioReplies: 9Last Post: 3rd Jun 2020, 05:08 -
Deinterlacing PAL HD video that's been converted to NTSC.
By xenodj in forum Video ConversionReplies: 15Last Post: 17th Mar 2020, 10:04 -
how can I batch EAC3To from 25FPS(pal) to 23.976FPS(NTSC)?
By aniel in forum AudioReplies: 2Last Post: 5th Feb 2020, 05:02 -
Remove ghosting on an NTSC 29.97fps possibly shot on PAL
By bruno321 in forum EditingReplies: 2Last Post: 10th Apr 2018, 09:54
