MeGui has a 'bitrate calculator' there we can assign a final size and know which bitrate to apply..
[Attachment 54595 - Click to enlarge]
of course the configuration is two passes責任者-MDX -
I remember learning my lesson back when I used AutoGK myself years ago. I encoded a bunch of episodes from a TV show using the same target file size for each and realised some episodes looked great while others... not so much. You either waste bitrate on episodes that don't need it, or use to little bitrate on others, or a combination of the two.
Unless you have a specific need for a particular file size it's much better to specify a quality instead. The file sizes will vary but the quality won't. After you've encoded that way for a while you'll settle on a quality that gives you the file size you want.... on average. I've got three seasons of an old TV show on my hard drive I just finished encoding from DVDs. Using the same encoder settings, quality and resolution each time, they range in size from 230MB to 380MB (including audio). They're all the same quality though.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
Ffmpeg — Specific of libx265
By Drag in forum EditingReplies: 2Last Post: 13th Oct 2018, 07:30 -
x264vwf filesize (H264 rendering KBPS and filesize insane)
By Joris Ceoen in forum EditingReplies: 11Last Post: 2nd Apr 2017, 09:49 -
Converting HuffYUV to something smaller filesize...
By VSz in forum Video ConversionReplies: 11Last Post: 18th Feb 2017, 09:55 -
MediaCoder - converts down to 30FPS but still same filesize?
By CursedLemon in forum Video ConversionReplies: 2Last Post: 26th Aug 2016, 13:11 -
Adobe premiere export settings for Best quality and lowest filesize?
By archz2 in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2016, 14:07
