  1. I'm trying to mix the Audio between 3 different clips but one of them is a much higher quality so I get this message. I'm getting the option to use either MergeChannel or ConvertToMono with MixAudio but I don't know how to go about it. Here's what I have.
    S9=S9.Trim(18978,19023)+S5.Trim(37875,37900)
    S1.Trim(100090,100245)
    MixAudio(S1,S9,1,1)
  2. It's probably because one is 5.1ch and the other is 2ch.
    You could downmix the 5.1ch audio to stereo before joining or mixing them. There's a bunch of downmixing functions here, but for a standard 5.1ch downmix:
    function Dmix6Stereo(clip a) {
      flr = GetChannel(a, 1, 2)
      fcc = GetChannel(a, 3, 3)
      lrc = MixAudio(flr, fcc, 0.3694, 0.2612)
      blr = GetChannel(a, 5, 6)
      return MixAudio(lrc, blr, 1.0, 0.3694)
    Or this is how MeGUI does it. The LFE channel is included (I normally don't include it when downmixing but it's up to you).
    function c6_stereo(clip a) {
    fl = GetChannel(a, 1)
    fr = GetChannel(a, 2)
    fc = GetChannel(a, 3)
    lf = GetChannel(a, 4)
    sl = GetChannel(a, 5)
    sr = GetChannel(a, 6)
    fl_sl = MixAudio(fl, sl, 0.2929, 0.2929)
    fr_sr = MixAudio(fr, sr, 0.2929, 0.2929)
    fc_lf = MixAudio(fc, lf, 0.2071, 0.2071)
    l = MixAudio(fl_sl, fc_lf, 1.0, 1.0)
    r = MixAudio(fr_sr, fc_lf, 1.0, 1.0)
    return MergeChannels(l, r)
    So I guess you'd do something like:
    S9=S9.Trim(18978,19023) ++ S5.Trim(37875,37900)
    S1.Trim(100090,100245).Dmix6Stereo()
    MixAudio(S1,S9,1,1)
    Assuming the S1 audio is 5.1ch.
    When you have it working, you might want to normalize each if them, as downmixing might cause clipping, but it's a two pass process so get it working first.
    S9=S9.Trim(18978,19023).Normalize() ++ S5.Trim(37875,37900).Normalize()
    S1.Trim(100090,100245).Dmix6Stereo().Normalize()
    MixAudio(S1,S9,1,1)
    I've been guessing, but that seems like it'd be the most likely cause.
  3. It's an AC3 file with one channel.
    The other 2 files have 2 channels.
    The DMixStereo doesn't work for me though, unless there's a plugin somewhere.
  4. I think you can convert the mono audio to 2 channel this way. I haven't tested it, but it should work.
    Audio = whatever
    A = GetChannel(Audio, 1)
    MergeChannels(A, A)
  5. I never could get that method to work. I started trying to use the ResampleAudio and MergeChannels function too:
    S1=S1.Trim(100090,100245).ResampleAudio(48000, 1)
    S9.Trim(18978,19023)+S5.Trim(37875,37900).MergeCha nnels(S1,S9)
    MixAudio(S1,S9,1,1)
    Now it's telling me that the number of audio channels do not match. Was hoping I was on the right path.
  6. Originally Posted by smike View Post
    MixAudio(S1,S9,1,1)
    That usually only happens when the number of audio channels don't match.
    I can only guess from your script, but, you've connected MergeChannels with a dot, so if the previous filter outputs audio, it'll use it for the clip1 input, you've specified two clips, so that's a total of three. I suspect you just need to unchain MergeChannels.
    S9.Trim(18978,19023)++S5.Trim(37875,37900)
    MergeChannels(S1,S9)
    MixAudio(S1,S9,1,1)
    Although S9 hasn't been redefined there, so it won't have a new value. You probably should update it or create a new variable, or replace it with "last" for MergeChannels.
    S9.Trim(18978,19023)++S5.Trim(37875,37900) # "last" should be updated to become the output after this line
    MergeChannels(S1,last)
    MixAudio(S1,last,1,1)
  7. That worked, thanks so much!
