I seem to have a unique issue. x264 randomly stops encoding for any source I try at random %'s. 20-70%! I don't know what the deal is. I've tried tmod x264, and x264 (x86). For the most part, the avisynth file is simple trims to remove commercials...and the source is fine. Doesn't matter which drive I choose either....
I'm thinking it may be my overclock ??? But I'm not sure why that would be the case..I'm mostly 5GHz stable...and a serious OCer helped me stress test it...
Any advice? Thanks all.
Overclock and/or CPU overheats.
Use a monitor program and check the temps -
Mostly? Lol... You must be 100% stable under even avx2 load!I'm mostly 5GHz stable.
You should never use an O/C'd cpu for any type of lengthy video encoding, 3d rendering and video encoding are 2 of the only tasks that I have seen that will make an O/C'd cpu crap its pants, even when said O/C has been stress tested extensively with Prime95 or heavy gaming.
Video encoding tends to punish cpu's alot, get rid of the O/C if you plan on encoding for more than a minute or two. -
How did you stress test it? Something like this?
https://files.extremeoverclocking.com/file.php?f=205
Something for temperature checking.
https://www.alcpu.com/CoreTemp/Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
Testing effects of CPU multi-threading on x264 encoding
By ziggy1971 in forum Video ConversionReplies: 49Last Post: 5th Mar 2019, 10:05 -
x264 limited by CPU cores/threads?
By TE16 in forum Newbie / General discussionsReplies: 25Last Post: 19th Dec 2018, 03:46 -
x264 benchmark? what mobile chipset to do more fast encoding x264 encoding?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2018, 23:06 -
Is a 6700K CPU good for x264 encoding using a Bluray as a source?
By MANswers in forum Newbie / General discussionsReplies: 8Last Post: 6th May 2016, 16:36 -
Out-of-alignment strip of video (x264 colour issues)
By koberulz in forum Newbie / General discussionsReplies: 130Last Post: 16th Jan 2016, 09:09
