i have a film in dv-avi with vertical jitter - any suggestions as to possible software that will help remove it?
sounds like it might have been captured wrong or you are watching it wrong. dv is bottom field first. make sure it's being displayed that way.
"Vertical jitter" could mean a few things, but for fixing old film, you can re-encode and calm a lot of it down with Stab. I've been using it a fair bit lately and haven't experienced the green tinting problem mentioned on the wiki, so it was probably a bug with a plugin.
If it's some other kind of jitter other than the entire frame "bobbing" up and down, you might need to be more specific.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Yes, the U/V drop (green tinting) in Stab (actually I think it was in DePan) was fixed a few years ago.
thank you all and yes bobbing up and down sounds like a better description
jitter on capture, but not on tv?
By tn-xyz in forum Capturing and VCRReplies: 21Last Post: 14th Apr 2017, 07:03 -
AVISynth: Removing Vertical Jitter
By IllusionSector in forum Newbie / General discussionsReplies: 22Last Post: 10th Feb 2017, 17:24 -
Vhs to DVD (horizontal jitter)
By Ferno411 in forum Video ConversionReplies: 1Last Post: 30th Dec 2016, 11:15 -
picture is shaky/jitter please help
By kt2016 in forum RestorationReplies: 18Last Post: 14th May 2016, 00:04 -
USB-AVCPT horizontal jitter
By johnshenry in forum Capturing and VCRReplies: 1Last Post: 11th Aug 2015, 22:20
