Hello,
I was wondering if it would be possible to re-use a usb hub from an old monitor. I got it out of one, but it appears to also got power from the monitor itself, with a 6 wire connection... Is there a way to wire it up to an external power supply to use the hub?
Thanks in advance!
wobelaar
	Not worth the effort. Much easier, and likely even cheaper, to just buy a new (and better) hub.
	You're probably going to need an electrics expert who's familiar with them for that one. You'll be lucky....
 USB Hubs are pretty cheap. Even USB 3.0 hubs these days. The cheapest passive USB 2 hub on Amazon at the moment is $1.87
 https://www.amazon.com/Detectorcatty-Splitter-Reader-Laptop-Computer/dp/B08115FL5B/ref...56&s=pc&sr=1-6
 And after a quick search I found a powered USB 3.0 Hub for $18.99
 https://www.amazon.com/RSHTECH-Splitter-Portable-Aluminum-Individual/dp/B07HMZSRS7/ref..._t3_B01HFWM9R2
 Chances are some of the wires power the hub itself while others supply power over the USB connection for devices that require it. That's a guess, but I'm not sure you could easily combine them to run from a single power supply.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
 Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
	I'd rather buy a good USB3 hub.
 Then recycle the monitor.
 Maybe even recycle after throwing it at a brick wall. Stress relief. Want my help? Ask here! (not via PM!) Want my help? Ask here! (not via PM!)
  Easiest way to play a usb video directly to a computer monitor.By nicksteel in forum Newbie / General discussionsReplies: 4Last Post: 10th Sep 2018, 05:18
  can't install Asmedia usb 3.0 driver/USB 3.0 Host Controller not foundBy clashradio in forum ComputerReplies: 18Last Post: 28th Sep 2017, 10:05
  Is there such a thing as a micro-USB hub?By ahhaa in forum ComputerReplies: 4Last Post: 23rd Oct 2016, 20:01
  Hdds on usb hubBy kyrcy in forum ComputerReplies: 2Last Post: 28th Aug 2016, 19:18
  TIP: If your USB hub suddenly stops working - Win 7By bahjan in forum ComputerReplies: 10Last Post: 3rd May 2015, 12:34
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
