  1. How to always force 60fps in Reclock's settings dialog window where there's a dropdown menu located on the top right corner? Most of the time the selection is set to "Unkown"
  2. ...or is there any way to set 60fps as default?
  3. If you open the ReClock configuration (from the start menu shortcut) you can set the default frame rate for when it's unknown, but the maximum appears to be 30fps. I'm not using the latest version though (I don't think), so maybe that's changed.
    Instead of messing with ReClock I'd be trying to work out why it can never determine the frame rate of your files. That seems to be more like a problem with them than with ReClock. Can you upload a small sample file?
