And yes, it is indeed out of sync. Trying to convert this from AVI to MKV, just dragging it in, editing some of the metadata, and multiplexing:track 0: This audio track contains 107 bytes of invalid data which were skipped before timestamp 00:54:26.016000000. The audio/video synchronization may have been lost.
Code:General Complete name : a.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.28 GiB Duration : 1 h 41 min Overall bit rate : 1 799 kb/s Writing library : VirtualDub build 29808/release Video ID : 0 Format : MPEG-4 Visual Format settings, BVOP : Yes Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 1 h 41 min Bit rate : 1 709 kb/s Width : 320 pixels Height : 240 pixels Display aspect ratio : 4:3 Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Compression mode : Lossy Bits/(Pixel*Frame) : 0.928 Stream size : 1.21 GiB (95%) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Codec ID : 55 Codec ID/Hint : MP3 Duration : 1 h 41 min Bit rate mode : Constant Bit rate : 80.0 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Compression mode : Lossy Stream size : 58.2 MiB (4%) Alignment : Split accross interleaves Interleave, duration : 42 ms (1.00 video frame) Interleave, preload duration : 500 ms
I generally use MKVToolNix for a job like this however I suspect with this source material it might be better to use Avidemux using the mkv muxer.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Personally I think they way MKVToolNixGUI skips non-audio data without adding silence to compensate is rather dumb.
I'd try splitting the MKV (or AVI) as close to 00:54:26.016 as you can (probably just before). Check the audio sync for the second output file, open it in MKVToolNixGUI and resave it while applying any delay you think is required to fix the video/audio sync. It might take a few goes, but when the resaved second section is fixed, you should be able to append it to the first section again. If there's important audio happening where it loses sync there might be a noticeable "glitch" in the Audio/Video sync after rejoining the files, but if that section of the audio is mainly silence it should work fine. It depends how close to it you can split the MKV etc.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
Avisynth - Audio track longer than video track
By martanius in forum AudioReplies: 4Last Post: 18th May 2018, 03:13 -
commands of MKVToolnixGui
By bennyutzer in forum Video ConversionReplies: 2Last Post: 25th Sep 2017, 18:38 -
MKVToolnixGUI(15) in batch mode?
By jack616 in forum EditingReplies: 2Last Post: 18th Sep 2017, 12:00 -
AC3 repair invalid data
By armin666 in forum AudioReplies: 3Last Post: 15th Aug 2017, 22:44 -
how to download this - Invalid data found when processing input
By bfa1trung in forum Video Streaming DownloadingReplies: 2Last Post: 20th Aug 2015, 10:51
