First of all, I wish to thank you very very much for creating FrostyBorders, it's been a literal lifesaver for my ultrawide OLED display when watching non-ultrawide content! I think it looks (and works) far better than SVP4's "Black Bars Outer Lighting" option, personally. The only thing I know of that can compete with FrostyBorders, is the "Ambient light for YouTube" browser plugin.
Having said that, I have a few remarks:Edit:
- To make videos load faster using AviSynthFilter, leave only one format selected under 'Input formats'.
- Your instructions on how to use FB at all are far too difficult to follow, for an average user...
- No matter how much I've tried, I can't seem to make it work via VapourSynthFilter :(
To make videos load even faster:
- Use 'GPlugin=0' (none) - the fastest.
- Use 'GPlugin=1' (AddGrainC) - slightly slower.
- Use the oldest version of 'neo_f3kdb' ('GPlugin=2') that works; recent versions seem to increase video loading time.
After literal weeks of figuring out how to make FB even work at all in the first place - I've compiled a small guide, which would hopefully help others like myself in the future. Some of this is not explained in the FrostyBorders Help file or this thread, so I had to figure it out on my own.
Now, is there any chance you could make a guide in a similar format, but for VapourSynth Filter?How to use FrostyBorders in MPC-BE/MPC-HC via AviSynth Filter, for dummies like me:If you've followed this guide correctly, FrostyBorders should now work in your player!
- Download and install AviSynth+ v3.7.3 (video playback never starts with FB on newer versions).
- Download and extract AviSynth Filters to a permanent location and run 'install.cmd' as administrator.
- Download AddGrainC (and/or neo_f3kdb) and FastBlur and extract them.
- Download FrostyBorders and extract it.
- Place AddGrainC.dll (and/or neo_f3kdb.dll), FastBlur.dll and FrostyBorders.avsi in C:\Program Files (x86)\AviSynth+\plugins64+.
- Create a new file at a permanent location, name it something like "FrostyBorders.avs", for example.
- Paste the following, most basic script into it, just to make it work for now; you can add more functionality to it later:
Code:AvsFilterSource() FrostyBorders(X,Y)- Replace X and Y in the above script with your display resolution's width and height, respectively; for example "(1920,1080)".
- Launch MPC-BE/MPC-HC, go to Options -> External Filters -> 'Add Filter...', select AviSynth Filter and press OK.
- Select the newly added AviSynth Filter and tick Prefer to the right of the list
- Double-click the AviSynth Filter in the list -> Browse -> navigate to the script you created above -> Open.
- Under Input Formats, leave only YV12 or P010 selected, and click OK, then OK again to close Options.
Pretty please! ♥
Results 211 to 226 of 226
Last edited by DwarfRose; 12th Aug 2025 at 13:11. Reason: Added another solution to slow video loading.
DwarfRose,
I haven't run the Vapoursynth version of FrostyBorders in MPC-HC for quite a while as I'm on Linux so I'm running it via SMPlayer/MPV instead, so this is from memory.....
For the Avisynth version, I think it'd be a good idea to use this script instead of the one you posted, as if borders don't need to be added it'll bypass Avisynth entirely. The FB_IsEqual function is included in FrostyBorders. Substitute your monitor's resolution in pixels for X and Y.
The Vapoursynth filter should work much the same way, only the script you use to run FrostyBorders must have a vpy extension.Code:AvsFilterSource() clip = last W = width(clip) H = height(clip) IsAspectEqual = FB_IsEqual(float(W)/float(H), float(X)/float(Y)) if (!IsAspectEqual) { FrostyBorders(clip, X,Y) } else { AvsFilterDisconnect() }
The FrostyBorders function itself should be in whatever location it needs to be so it can be automatically imported. On Windows (not a portable install of VapourSynth) I've been putting functions in
and plugins inCode:"C:\Users\YourUserName\AppData\Roaming\Python\Python313\site-packages"
The required plugins are listed in the help file.Code:"C:\Users\YourUserName\AppData\Roaming\VapourSynth\plugins64"
For me, the Vapoursynth filter wouldn't run unless I edited the registry to increase the frame buffer. I think TemporalSoften was the culprit there. Increasing it didn't help with the Avisynth filter opening slowly though.Code:import vapoursynth as vs core = vs.core import FrostyBorders as fb clip = VpsFilterSource W = clip.width H = clip.height IsAspectEqual = fb.FB_IsEqual(W/H, X/Y) if not IsAspectEqual: fb.FrostyBorders(clip, X,Y).set_output() else: VpsFilterDisconnect = True
Adding the "InitialSrcBuffer" registry entry with a value of 6 seemed to do the trick.
https://github.com/CrendKing/avisynth_filter/wiki/Configuration
You should be able to save this as a reg file and import it into the registry if it's easier.
I've typed everything above without actually testing it as I'm a bit short on time today, but it should be fine. Let me know if that helps.Code:Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\AviSynthFilter\VapourSynth Filter] "InitialSrcBuffer"=dword:00000006
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
Thank you so much for the reply!
I'll try 'making friends' with VapourSynthFilter again using your guide and script :)
Oh! I didn't realize that FB could already check for that, thank you!
I only shared that script as part of the guide as it's the most basic stuff that's required for FB to even run at all, which wasn't obvious to me, so I assumed it wouldn't be obvious to others using AviSynthFilter for the first time.
Otherwise, I'm already doing the same thing you suggested, but differently, in the script that I personally use.
I also check for other stuff, such as whether the video is vertical or smaller than the lowest reasonable resolution:
Are any of the other checks that I use here also included in FrostyBorders?Code:AvsFilterSource() srcW = Width() srcH = Height() # Determine the video's aspect ratio ar = Float(srcW) / Float(srcH) # Check if the video already has an aspect ratio of 2.39:1 tolerance = 0.01 isCinematic = Abs(ar - 2.39) < tolerance # Check if the video is vertical isVertical = srcH >= srcW # Check if the video is too small isSmall = srcH < 480 # If either, do '?', else do ':' ( isCinematic || isSmall || isVertical) \ ? AvsFilterDisconnect() \ : FrostyBorders(3440, 1440, Feather=32, StaticT=false, GPlugin=2)
Again, thank you so much for creating FrostyBorders and being active! ♥ -
The IsEqual function is used in a few places in the FrostyBorders and CropResize scripts to prevent them cropping unnecessarily due to floating point math often only being accurate to about 4 decimal places. It can be an issue when resizing anamorphic sources to non-anamorphic dimensions.
Not a real world example, but it's possible that after any cropping, the width could be calculated to be resized to something like 703.999997453 pixels instead of exactly 704, causing the function to apply additional cropping so it can be resized to 700 instead. That sort of thing....
The IsEqual function isn't as tolerant as the calculation in your script though, so you might prefer to leave it as you're currently doing it.
In the FrostyBorders script, I think FB_IsEqual is only used to check whether the result of a calculation is close enough to an integer to use the integer. Something like:Code:function FB_IsEqual(Val1, Val2) { return (abs(Val1 - Val2) < 0.00005) }
X = float(Y) / float(Z)
X = FB_IsEqual(round(X), X) ? round(X) : X
I can't think of anything else you might need. If you still can't get the Vapoursynth filter to work post back and I'll help if I can.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
There's a new version of FrostyBorders dated 2025-12-20 in the opening post.
Avisynth version:
No change in functionality.
Formatted the function syntax to make it a little more readable.
VapourSynth version:
Added the ability to use the ZSmooth plugin for temporal softening.
FrostyBorders now looks for the following plugins in the following order (only one is required):
ZSmooth, TemporalSoften2 and TemporalSoften.
ZSmooth and TemporalSoften2 also require the Miscellaneous Filters plugin, therefore it also needs to be
loaded before either of those plugins will be used. The help file contains a link for each plugin.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Apologies if this has been asked and answered before, but is it normal that FrostyBorders only works with AviSynth+ version 3.7.3?
When trying to play the same video file with the same FrostyBorders settings using versions 3.7.4, 3.7.5 or 3.7.6 (pre-release), both MPC-BE and MPC-HC seem to freeze up completely. -
Hi.
No that shouldn't be the case. I mainly use the VapourSynth FrostyBorders now in MPV player as I switched to Linux, so I can't remember the last version of Avisynth+ I used it with. I'll play around with it and get back to you, probably tomorrow.
In the mean-time could you try using the CropResize script in my signature? You can enable adding FrostyBorders this way:
CropResize(1920,1080, Frosty=true)
It doesn't require the stand-alone FrostyBorders function, so it'll be interesting to see if you have the same problem with it. It could be a plugin issue rather than the function itself.
Cheers.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
DwarfRose,
Opening a script directly with MPC-HC works fine with the 14th Feb Avisynth+ pre-release (there's a newer one I haven't tried yet), at least when Avisynth+ and MPC-HC are running in Wine on Linux.
CropResize(960,720) # just to crop the video to 4:3
FrostyBorders(960,540)
Subtitle(VersionString(), align=5)
[Attachment 91235 - Click to enlarge]
Are you running FrostyBorders via avisynth_filter (instructions in post #2) or opening a script directly? If it's the former, maybe newer Avisynth+ versions and avisynth_filter aren't getting along. If that's the case can you test running a script via avisynth_filter without FrostyBorders included, or try increasing the avisynth_filter frame buffer. That fixed a similar problem for me with the VapourSynth version of the filter, so you could try doing the same for Avisynth. Create the following as a *.reg file and import it into the Windows registry (I think it's the correct reg entry).
https://github.com/CrendKing/avisynth_filter/wiki/ConfigurationCode:Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\AviSynthFilter\AviSynth Filter] "InitialSrcBuffer"=dword:00000006
I probably won't get a chance to check out if it's an avisynth_filter issue until tomorrow, but let me know if any of that helps.Last edited by hello_hello; 16th Feb 2026 at 21:10.
Thank you!
Increasing the buffer size in the registry completely solved it! And playback also feels much snappier now.
Why isn't that buffer size thingy larger by default..?
Also, when I tried your script, this one:
...the only thing that happened was that the player showed a "CropResize function doesn't exist" error message.Code:CropResize(960,720) # just to crop the video to 4:3 FrostyBorders(960,540) Subtitle(VersionString(), align=5)
CropResize is a separate function. There's a link in my signature with example screenshots in post #2.
The only reason I added it to my script is because I didn't have a 4:3 video handy, so I used it to crop a video to 4:3 before adding borders with FrostyBorders.
FYI: Normally if you resize a picture to 4:3 dimensions but it's not 4:3 (as an example), it'll squish or stretch the picture in some way. The purpose of CropResize is to ensure the picture is never distorted, so it either crops as necessary before it resizes, or adds borders as required the way FrostyBorders does.Last edited by hello_hello; 18th Feb 2026 at 07:51.
Avisynth or VapourSynth version?
If they're being deleted, it's not by the function itself. The only frame properties the standalone version of FrostyBorders checks for and modifies are the SAR frame properties, as it always resizes to a 1:1 SAR.
I just checked with AvsPmod running Avisynth+ r4604 and the few frame properties there were survived.
Below are before and after FrostyBorders screenshots.
Before
[Attachment 93250 - Click to enlarge]
After
[Attachment 93251 - Click to enlarge]Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
It deletes literally all of them. I'll post the syntax when I'm at my computer—I used it with the function that mirrors the image into the black bars (I don't remember* the name of the option, of course).
Edit: AviSynth.
Edit 2: *clone. -
You could try disabling blurring and grain, as that should completely bypass the only two plugins used, just in case one of them is the cause.
FrostyBorders(1280,720, Clone=1, Blur=0, Texture=0)
The SAR frame properties should remain though, as writing them is the very last thing the function does (line 1128).
Tweak() and Levels() are also used, but they're built in Avisynth functions so they should be okay.
Or try just FrostyBorders() as it should output the original video without borders or resizing, assuming it's not anamorphic.
If Avisynth+ is lower than r3593, frame properties aren't checked as I think r3593 was the first official release to support them.
Edit: You could also try the frosty borders function included with CropResize. It should be exactly the same, although the options are specified a little differently, and CropResize supports an anamorphic output.
FrostyB(Clone=1, Blur=0, Texture=0)
CropResize(1280,720, Frosty=true)Last edited by hello_hello; 2nd Aug 2026 at 09:44.
Blur=0 - now properties are passed correctly.FrostyBorders(1280,720, Clone=1, Blur=0, Texture=0)
Properties are deleted.FrostyB(Clone=1, Blur=0, Texture=0)
CropResize(1280,720, Frosty=true) -
Frame properties support was added to FastBlur in version 0.3.2, along with a bug fix, although the latest is version 4.0.
I'm not sure why the Avisynth wiki hasn't been updated. It still only has a link for version 0.3.1.
I don't know why frame properties are still being deleted when the CropResize version of frosty borders uses Blur=0. Maybe FastBlur isn't being bypassed entirely as it should be. I'll have to check, but frame properties aren't nuked when the latest FastBlur is used.Last edited by hello_hello; 2nd Aug 2026 at 15:48.
AudioSpeed & AudioMeter/AudioWave scripts
By hello_hello in forum AudioReplies: 21Last Post: 25th Sep 2022, 02:35 -
ffmpeg script
By loa909 in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2018, 12:15 -
Need a particular 3D avisynth script
By mazinz in forum Video ConversionReplies: 8Last Post: 25th Feb 2018, 05:55 -
SW Script
By suadnovic in forum SubtitleReplies: 2Last Post: 30th Nov 2016, 11:13 -
Best possible AviSynth Script
By Suwadith in forum Video ConversionReplies: 31Last Post: 10th Sep 2015, 07:43
