Page 5 of 5
FirstFirst ... 3 4 5
Results 121 to 137 of 137
  1. There's a new version of CropResize dated 2022-10-04 in the opening post.
    Just a minor regression fix.
  2. Deleted (double post)
  3. There's a new version of CropResize dated 2022-11-01 in the opening post.
    Fixed packed RGB cropping (RGB24, RGB32 etc) when the AVSResize and FMTConv plugins are resizing (the video was being resized without any cropping being applied).
    Fixed AutoDAR=true ignoring the specified mod width or height (default Mod=4).
  4. There's a link for a new version of CropResize dated 2022-11-19 in the opening post.
    The pictures demonstrating CropResize usage in the 2nd post have also been updated.
    Fixed a 2022-09-22 regression when NoResize=true or ResizeWO=true and CSplit=1 (the default).
    Specifying non-mod cropping (ie not mod2 for YV12) could result in an error message or the cropping
    being adjusted slightly incorrectly.
    The display and sample aspect ratios shown when Info=true should still have been correct though.
    Changed the displayed info when a cropping preview is enabled, mainly to show the display and
    sample aspect ratios as float (ie 1.777778) as well as a fraction (ie 16:9).
  5. There's a link to a new version of CropResize dated 2023-06-02 in the opening post.
    The new version updates the built-in frosty borders function to match the latest update to the standalone FrostyBorders script. There's no other changes.
  6. There's a link for new a version dated 2023-07-14 in the opening post. Just a couple of minor gremlin fixes.
  7. Thank you so much for making this. It's a major quality of life improver!!
  8. You're welcome.
    As a way of learning how to use it, I'm currently working on a native Vapoursynth version, so I'll upload that when it's finished. There'll probably be a new version of CropResize (Avisynth) to go with it, although I don't think there'll be any changes in functionality, just some syntax tweaking.
  9. There's a link for new a version dated 2023-09-26 in the opening post.
    The major changes are listed above that link.
    CropResize now comes in both Avisynth and VapourSynth flavours.
  10. Sorry about the quick update, but there's a link for new a version dated 2023-09-28 in the opening post.
    Fixed a couple of regressions in version 2023-09-26.
    There was a typo in the VapourSynth version preventing an output sample aspect ratio being used.
    The Avisynth version was producing an error message when a copping preview was enabled while Info=true.
    While I was updating I tweaked the way Info displays a frame properties sample aspect ratio of 1:1 so at first glance the source video doesn't appear to be anamorphic.
  11. There's a link for a new version dated 2023-10-02 in the opening post.
    The "CropResize Changes" text file contains the details.
  12. There's a link for a new version dated 2023-10-11 in the opening post.
    Fixed a minor bug in the VapourSynth version. The Avisynth version hasn't changed (only the date to keep the two flavours the same).
  13. Another minor bug fix. The Avisynth version this time. There's a link for the new version dated 2023-10-12 in the opening post.
  14. New version dated 2023-10-28 in the opening post.
    The only change is a bug fix for one of the included resizer wrapper functions.
  15. There's a link for a new version of CropResize dated 2025-06-16 in the opening post.
    The main cropping and resizing functionality remains the same, however quite a few changes have been introduced, so if you've used the function in the past the Changes text file would be worth reading. The main change to note for the Avisynth version of CropResize is Avisynth+ 3.7.1 is now a minimum requirement.
  16. Deleted (accidental double post)
  17. There's a link for a new version of CropResize dated 2025-12-20 in the opening post. There's only a few minor changes to the CropResize function (see the CropResize Changes text file).
    Based on an idea from rgr at doom9, a new function, CombineClips has been added (for both Avisynth and VapourSynth).
    It's been updated and incompatible with the standalone CombineClips function I previously linked to at doom9.
    By default borders are added as required to prevent aspect error, but borders can be disabled and the function will crop to prevent aspect error instead.
    There's a separate CombineClips help file included, but below are some examples with screenshots.
    Anamorphic clips must have an appropriate sample aspect ratio in frame properties otherwise they won't be resized correctly.
    The four source clips were taken from the same video (with a 2:1 aspect ratio), but they're resized and/or cropped differently.
    832x468 16:9 dimensions and display aspect ratio.
    A = CropResize(832,468).Subtitle("A", align=5)
    720x576 PAL dimensions and a 16:9 display aspect ratio.
    B = CropResize(720,576, OutDAR=16.0/9.0).Subtitle("B", align=5)
    800x400 2:1 dimensions and display aspect ratio.
    C = CropResize(800,400).Subtitle("C", align=5)
    720x480 NTSC dimensions and a 4:3 display aspect ratio.
    D = CropResize(720,480, OutDAR=4.0/3.0).Subtitle("D", align=5)
    The output frames are stacked to make the result easier to see.
    The help file has info on using the Max argument.
    Avisynth syntax is used below, but the VapourSynth syntax is very similar.
    Setting the desired output width with Max=True.
    CombineClips will calculate the appropriate height based on the clip with the greatest display aspect ratio.
    The output is 960x480 (2:1 DAR).
    CombineClips([A,B,C,D], 960,0)
    Setting the desired output width with Max=False.
    CombineClips will calculate the appropriate height based on the clip with the smallest display aspect ratio.
    The output is 960x720 (4:3 DAR).
    CombineClips([A,B,C,D], 960,0, Max=False)
    Specifying the desired output dimensions with borders enabled.
    If those dimensions don't match the resizing dimensions of at least one clip, every clip will have borders added.
    CombineClips([A,B,C,D], 768,360)
    Specifying the desired output dimensions with borders disabled.
    CombineClips([A,B,C,D], 768,360, Borders=False)
    Resizing to 720x480 NTSC dimensions with a 16:9 display aspect ratio and adding borders as required.
    CombineClips([A,B,C,D], 720,480, OutDAR=16.0/9.0)
    Displaying the cropping and resizing for each video.
    CombineClips([A,B,C,D], 960,480, Info=True)
