I'm trying to remove a logo from a clip, but when I use Inpaintfunc or rm_logo MeGUI shows an error saying: "There is no function named "imagesource"".
This only happens when using the portable avisynth(avs+ r2544); The installed version(2.6.0.6) doesn't have this problem.
Am I doing something wrong ?
Results 1 to 9 of 9
There is no official portable AviSynth. As discussed here,
A workaround was posted , but now it's been deleted.The problem isn't Avisynth itself, it requires few if any regkeys. The problem is that Windows isn't aware that Avisynth is an input filter or even exists, without certain keys.
If you don't need strict portability, try copying DevIL.dll to the system folder.
http://avisynth.nl/index.php/ImageSource#Notes -
I meant MeGUI's own AviSynth version.There is no official portable AviSynth. As discussed here,
There were already two DevIL dlls, one in System32 and the other in SysWOW64. The one in SysWOW64 was v1.6.4 so I replaced it with the newer version from your link; Still the same error.A workaround was posted , but now it's been deleted.
There's also a DevIL.dll in tools->avs which I tried to load manually, but that didn't work either. -
Oh well, it was a guess. Here's another - I've seen "no function named X" when actually it exists, but it's called with invalid arguments (source clip undefined, float argument instead of int, etc). Don't how that can happen within a MeGUI-generated clip, but the point is, that particular error message can be misleading.
I forgot to say that I had AviSynth+ r2508 installed (x64 only), and the one in SysWOW was 2.6.0.6 so I just installed AviSynthPlus-MT-r2580 (both x86 and x64) to see whether the problem was MeGUI's AVS+, and that fixed it. But the odd thing is that the MeGUI's own AviSynth was active as you can see below, I thought that meant MeGUI won't use the installed AviSynth. So I guess the problem was that MeGUI was using AVS 2.6 although it was inactive.
Code:--[Information] AviSynth Information ---[Information] AviSynth Wrapper ----[Information] Version: 1.0.2721.0 ----[Information] Date: 29-04-2017 ----[Information] Interface: 3 ---[Information] AviSynth ----[Information] File Version: 0.1 ----[Information] Date: 27-12-2017 ----[Information] Name: AviSynth+ 0.1 (r2580, MT, i386) ----[Information] Version: AviSynth+ 0.1 (r2580, MT, i386) ----[Information] AviSynth+: true ----[Information] MT: true ----[Information] Status: inactive ---[Information] AviSynth portable ----[Information] File Version: 0.1 ----[Information] Date: 15-11-2017 ----[Information] Name: AviSynth+ 0.1 (r2544, MT, i386) ----[Information] Version: AviSynth+ 0.1 (r2544, MT, i386) ----[Information] AviSynth+: true ----[Information] MT: true ----[Information] Status: active
Yeah, everything from here:
vquynh,
I'm fairly sure ImageSource requires ImageSeq.dll to be loaded for Avisynth+. It should be included with the Avisynth installer or in the zip file if you downloaded the non-installer version. If you haven't installed Avisynth and you're only using MeGUI's portable version, you should find it in the
"MeGUI\tools\avs\plugins" folder
so try:
LoadPlugin("_Path_\MeGUI\tools\avs\plugins\ImageSe q.dll")
at the top of the script.
Which version of Avisynth were you using prior to Avisynth+ 3.6.1?
I'm still using Avisynth+ 3.5 as MeGUI's portable version and ImageSeq needs to be loaded. It's not something that changed recently.
I still have Avisynth 2.6 installed, so I created a script that lives in the installed Avisynth plugins folder and loads the additional Avisynth+ plugins when MeGUI's portable Avisynth+ runs. For me it looks like this:
You could change the file paths accordingly and save it as a script, then add it to the top of the Avisynth templates you use. If you called it ExtraPlugins.avs,Code:function AutoLoad_IsAVSPlus() { return findstr(lcase(versionstring), "avisynth+") > 0 } ConvertingStacks = "C:\Program Files\MeGUI\tools\avs\plugins\ConvertStacked.dll" AutoLoad_IsAVSPlus() && exist(ConvertingStacks) ? LoadPlugin(ConvertingStacks) : nop() ImageSequencing = "C:\Program Files\MeGUI\tools\avs\plugins\ImageSeq.dll" AutoLoad_IsAVSPlus() && exist(ImageSequencing) ? LoadPlugin(ImageSequencing) : nop() Shibatching = "C:\Program Files\MeGUI\tools\avs\plugins\Shibatch.dll" AutoLoad_IsAVSPlus() && exist(Shibatching) ? LoadPlugin(Shibatching) : nop() TimeStretching = "C:\Program Files\MeGUI\tools\avs\plugins\TimeStretch.dll" AutoLoad_IsAVSPlus() && exist(TimeStretching) ? LoadPlugin(TimeStretching) : nop() VDubFiltering = "C:\Program Files\MeGUI\tools\avs\plugins\VDubFilter.dll" AutoLoad_IsAVSPlus() && exist(VDubFiltering) ? LoadPlugin(VDubFiltering) : nop()
then adding
Import("Path/ExtraPlugins.avs")
to the top of a script template should load those extra dlls automatically. Just a thought....
I guess it's possible that older versions of those plugins need to be updated for a newer version of Avisynth. If MeGUI updated Avisynth+ to 3.6.1 it should've updated the plugins in the avs/plugins folder as well. If you updated Avisynth+ yourself, it'd pay to update those plugins... assuming there's newer versions included with Avisynth+ 3.6.1.Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
Which are the free alternatives to VideoReDo's "QuickStream Fix" function?
By falco2000 in forum Newbie / General discussionsReplies: 10Last Post: 19th Mar 2022, 15:19 -
qtgmc error "there is no function named removegrain"
By codemaster in forum Video ConversionReplies: 6Last Post: 17th Jun 2017, 13:51 -
is there a "smoothFPS2" function in ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 7Last Post: 19th Mar 2016, 14:03 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
AvsPomd: Script error: there is no function named "ffinfo"? pls help?
By mrdodoubler in forum Newbie / General discussionsReplies: 4Last Post: 28th Jul 2014, 05:17
