I have a sharp DV-600 DVD player that playes VCDs. I tried the SVCD trick to get it to play SVCDs. I take my MPEG-2, multiplex it into a MPEG-2 with an MPEG-1 heading. I then then burn a non-standard VCD in Nero. I load it, and it recognizes it as a VCD. It plays no video, and plays the first 1/2 second of audio. GLIMMER OF HOPE!!! Anything I'm doing wrong? Should I switch software? Anybody with experience with Sharp players or this same problem?
Thanks so much
-Chris
search for your player in the compatibility list. there you have info on what kind of vcds / cd-r(w) can be read
That's just it, My player is NOT designed to play SVCDs, but I was trying to use the trick to get it to play one. When it did, i got a 1/2 second of audio and no video. Any help?
Thanks -
Has anyoner else experienced a short audio seuquence and no video when trying the SVCD trick?
Chris -
A XVCD with MPEG-2 video is very very off standard. Probably your player can not handle it.
Sorry mate,
I had one of these. The ONLY thing it will play are standard VCDs and standard VCDs with 128k audio. Anything else will just not work. XVCDs with constant bitrate will sometimes display but the audio de-synchs almost immediately.
I gave this to my sister-in-law and got a CONIA M-100. Cheap and plays darn near anything
Good luck,
Ian
Trick PSP video
By jntaylor63 in forum Video ConversionReplies: 0Last Post: 4th Aug 2011, 10:42 -
wireless Networking (router trick)
By stiltman in forum ComputerReplies: 0Last Post: 26th Mar 2009, 00:18 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
Help Nero is not doing the trick
By breeze9 in forum Authoring (DVD)Replies: 6Last Post: 1st Feb 2008, 09:36 -
Is there some trick to putting in a video card?
By videobread in forum ComputerReplies: 12Last Post: 21st Jun 2007, 22:07
