Someone please help!
I am converting a Divx DVD rip that is burned to a cd-r, to vcd. I am using the ntsc film template as I want to keep the frame rate at 23.976 fps. The film I am doing is Atlantis by Divx Dominion. The first time I encoded it there was no audio at all. So I extracted the audio, converted it to mpa and multiplexed it with the video stream, but then it gets out of sync! IT works fine in its mpeg 4 file, is there any hope at all?![]()
This works for me, every time.
Tmpgenc (newest 2.53), you have to give the Direct Show reader, higest priority. Options->envierment settings.
Know just load your avi as audio in Tmpgenc, and convert it, and then multiplex it together.
hope it helps
frotsen
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14
