I tried to solve this since few days with no luck so far, so please help...
I have a mkv HD file (720p) with video encoded in h.264 format and 5.1 audio in DTS format. What I need is an avi file, the same resolution, video encoded in xvid (or divx), 5.1 audio preferably untouched (DTS) or converted to AC3 if it's not possible. But 5.1, not stereo mp3.
I'm on linux so I worked only with mencoder so far. The first try was:
mencoder movie.mkv -ffourcc XVID -ovc lavc -lavcopts vcodec=mpeg4:threads=8:vbitrate=3000 -oac copy -o movie.avi
Video of the resulting file seems all right, but I get lots of "Skipping frame" errors from mencoder during encoding (like every 2 seconds) and audio (it's DTS all right) goes out of sync after a while.
I also found some option (googling) to get rid of this "skipping frame" errors. The result was an xvid/dts avi file, with audio much more out of sync, than before.
Then I tried to reencode dts into ac3 with this command:
mencoder movie.mkv -ffourcc XVID -ovc lavc -lavcopts vcodec=mpeg4:threads=8:vbitrate=3000 -oac lavc -lavcopts acodec=ac3:abitrate=384 -channels 6 -o movie.avi
Video was all right again, but there is no sound at all when I watch the movie. Media info tool and "codec info" from VLC say there os 5.1 AC3 sound, but can I hear no sound at all.
I also tried:
mencoder movie.mkv -ffourcc XVID -ovc lavc -lavcopts vcodec=mpeg4:threads=8:vbitrate=3000:cmp=2ubcmp=2:trell=yes:v4mv=yes:mbd=2 -oac lavc -lavcopts acodec=ac3:abitrate=384 -channels 6 -af channels=6:6:0:0:4:1:1:2:2:3:3:4:5:5 -o movie.avi
with the same result.
Any ideas?
Edit1: as far as I can tell there is no variable framerate or bitrate anywhere in the input file involved - see output of the MediaInfo below.
Edit2: here info about input file (output from MediaInfo):
Code:General Count : 246 Count of stream of this kind : 1 Kind of stream : General Kind of stream : General Stream identifier : 0 Inform : Matroska: 4.37 GiB, 1h 28mn Count of video streams : 1 Count of audio streams : 1 Video_Format_List : AVC Video_Format_WithHint_List : AVC Codecs Video : AVC Video_Language_List : English Audio_Format_List : DTS Audio_Format_WithHint_List : DTS Audio codecs : DTS Complete name : *** Folder name : *** File name : *** File extension : mkv Format : Matroska Format/Url : http://packs.matroska.org/ Format/Extensions usually used : mkv mka mks Codec : Matroska Codec/Url : http://packs.matroska.org/ Codec/Extensions usually used : mkv mka mks File size : 4695226405 File size : 4.37 GiB File size : 4 GiB File size : 4.4 GiB File size : 4.37 GiB File size : 4.373 GiB Duration : 5309313 Duration : 1h 28mn Duration : 1h 28mn 29s 313ms Duration : 1h 28mn Duration : 01:28:29.313 Overall bit rate : 7074702 Overall bit rate : 7 075 Kbps Encoded date : UTC 2008-06-17 22:21:16 Writing application : mkvmerge v2.2.0 ('Turn It On Again') built on Mar 4 2008 12:58:26 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Writing library : libebml v0.7.7 + libmatroska v0.8.1 Video Count : 134 Count of stream of this kind : 1 Kind of stream : Video Stream identifier : 0 Inform : English, 5 250 Kbps (5 562 Kbps), 1280*544 (2.35), at 23.976 fps, AVC (Container profile=Unknown@5.1) (High@L5.1) (CABAC / 5 Ref Frames) ID : 1 ID : 1 UniqueID : 1 Format : AVC Format/Info : Advanced Video Codec Format/Url : http://developers.videolan.org/x264.html Format profile : High@L5.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, CABAC : Yes Format settings, ReFrames : 5 Format settings, ReFrames : 5 frames Muxing mode : Container profile=Unknown@5.1 Codec ID : V_MPEG4/ISO/AVC Codec ID/Url : http://ffdshow-tryout.sourceforge.net/ Codec : V_MPEG4/ISO/AVC Codec : AVC Codec/Family : AVC Codec/Info : Advanced Video Codec Codec/Url : http://ffdshow-tryout.sourceforge.net/ Codec profile : High@L5.1 Codec settings : CABAC / 5 Ref Frames Codec settings, CABAC : Yes Codec_Settings_RefFrames : 5 Duration : 5304000 Duration : 1h 28mn Duration : 1h 28mn 24s 0ms Duration : 1h 28mn Duration : 01:28:24.000 Bit rate : 5249684 Bit rate : 5 250 Kbps Nominal bit rate : 5562000 Nominal bit rate : 5 562 Kbps Width : 1280 Width : 1 280 pixels Height : 544 Height : 544 pixels Pixel Aspect Ratio : 1.000 Display aspect ratio : 2.353 Display aspect ratio : 2.35 Frame rate : 23.976 Frame rate : 23.976 fps Frame count : 127296 Resolution : 24 Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Scan type : Progressive Interlacement : PPF Interlacement : Progressive Bits/(Pixel*Frame) : 0.314 Delay : 0 Writing library : x264 - core 60 r886 1075536 Writing library : x264 core 60 r886 1075536 Writing library/Name : x264 Writing library/Version : core 60 r886 1075536 Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5562 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:1.00 Language : en Language : English Audio Count : 121 Count of stream of this kind : 1 Kind of stream : Audio Kind of stream : Audio Stream identifier : 0 Inform : 1 536 Kbps, 48.0 KHz, 6 channels, DTS ID : 2 ID : 2 UniqueID : 2708952726 Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Codec : DTS Codec : DTS Duration : 5309313 Duration : 1h 28mn Duration : 1h 28mn 29s 313ms Duration : 1h 28mn Duration : 01:28:29.313 Bit rate mode : CBR Bit rate mode : Constant Bit rate : 1536000 Bit rate : 1 536 Kbps Channel(s) : 6 Channel(s) : 6 channels Channel positions : Front: L C R, Surround: L R, LFE Channel positions : 3/2.1 Sampling rate : 48000 Sampling rate : 48.0 KHz SamplingCount : 254847024 Resolution : 24 Resolution : 24 bits Delay : 0 Video delay : 0 Video0 delay : 0
On linux, you could try avidemux, with the dts addon
http://www.avidemux.org/admForum/viewtopic.php?pid=18985#p18985
If you have access to Windows, there are many more options -
Thanks for your advice, poisondeathray.Originally Posted by poisondeathray
I tried avidemux (had to compile it from sources to enable dts library under linux), but for some reason it recognizes only 2 channels in the input DTS stream. But MediaInfo, says it's 6 channel DTS. Any ideas why?
Video conversion (h.264->xvid) works as expected, AC3 sound in the output file can be heard, but there are only 2 channels available... -
It seems I found the solution, so I post it here in case somebody has similar problems.
I managed to transcode my mkv/h.264/dts video to avi/xvid/dts using mencoder without reencoding audio (just copying the audio stream) and without these strange a/v out of sync problems.
Here my understanding, what caused the problems. Somebody correct me if I got it wrong...
The original video was encoded with the standard 23.976 fps. At least this is what MediaInfo and media players displayed. But it seems this value was read just from some file/container header and the real framerate was a bit higher (slightly above 24 fps). Hence the "skipping frame" warnings every 2 seconds from mencoder. Mencoder tried to encode in the same framerate it believed the source material was (23.976 fps), but there was more frames per second in the actual video stream. Automatic skipping of frames tried to remedy the problem, but was inaccurate and after a while the sound went out of sync.
And here the solution. I used -ofps option of mencoder to set fps of the output video to the right value. I found it by trial&error - the goal was to achieve encoding process without "skipping frame" or "duplicate frame" (the opposite) warnings. The right value I found at last was 24.405 fps, which is pretty strange (not one of the standard fps values), but works for this particular file like charm. No a/v out of sync issues at all anymore.
So... here the command I used for reference:
The -ofps value is good only for my particular strange input file of course. Mostly the standard values (23.976 fps, 25 fps etc.) should work I think - so no -ofps setting needed here. If not, the right value has to be found by trial&error again.Code:mencoder input.mkv -noodml -ofps 240000/9834 -ffourcc XVID -ovc lavc -lavcopts vcodec=mpeg4:threads=8:vbitrate=4000:cmp=2:subcmp=2:trell=yes:v4mv=yes:mbd=2 -oac copy -channels 6 -o output.avi
MKV to AVI Audio Sync Problem
By adalect in forum Video ConversionReplies: 26Last Post: 18th Dec 2012, 04:09 -
.mkv to .avi audio is out of sync
By gartzo in forum Video ConversionReplies: 3Last Post: 10th Jun 2011, 17:12 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
mkv to avi - audio out of sync problem
By HitcherUK in forum Video ConversionReplies: 4Last Post: 28th Oct 2007, 10:16 -
Converting .avi (Xvid) to .mp4 or .mkv (H.264 or x.264) w/ subs
By Tensai in forum Video ConversionReplies: 4Last Post: 18th Jul 2007, 10:25
