i have a DVD file (MPG) which i want to compile to a DVD stracture with DVD Lab Pro.
and since DVD Lab Pro does not support non-elementary files as input - i had to click "Yes" when it asked me if i want to demux the input file to an elementary files.
so after makin' menus and such i clicked "Compile DVD" and the compiling process goes well but stucks little before its end...
this is the massage it's showing me when the process stucks:
now what i dont understand is:
how can it be? the program itself demuxed my file!
what is it all about?
by-the-way,
whenever i open this project this pops up:
i dont know if it has something to do with my problem but anyway - what is that mean?
any help appreciated!!!
Thank you!
Read my blog here.
guns1inger, thanks for the reply,
it come from a video camera,Originally Posted by guns1inger
i took my video camera to a Photo shop and he burned all its content to two DVD-R's.
so i copied the first DVD-R to my PC, demuxed it to M2V and AC3 files with PGCDemux, but then, i relized it will be much more easier for me to edit the video when it's non-elementary files (some guy from the forum adviced me to), so i muxed it to MPG file with ImagoMPEG-Muxer, i segmented the parts i wanted to author, then i'm coming to author it with DLP... the rest of the story is known...
i'v tried to do it, but, PgcDemux only know how to handle an IFO files... my source is MPG file...Originally Posted by guns1inger
thanks again man!!! -
Rejig can demux mpg files.
I would try going back to the originals, then using VOB2MPG to get the mpg file. Edit the mpeg file with a good mpeg editor (I like Womble Mpeg Wizard), then demux and author.
I suspect your current problems come from either the way you remuxed, or the way you cut the file up.Read my blog here.
i thought so too...Originally Posted by guns1inger
i'll try your advice and post back.
Thanks for the great help man!
you're the best!!! -
guns1inger,
i dont have the original DVD-R anymore (it took a plan along with my friend to out of Israel) but what i do have is the elementary streams i demuxed from the origin source (from the DVD-R's) with PgcDemux - i hope it is not what's causing the problem.
anyway - i muxed the elementary streams (M2V & AC3) again with ImagoMPEG-Muxer (could it be the cause?) and used Womble Mpeg Wizard (great tool by-the-way, thanks!) to cut un-wanted video parts and to make one big MPG file (3.71 GB weight, 01:48:49 long) but this time, i used Rejig to demux the MPG file to M2V and AC3 files.
i loaded the new elementary streams (video & audio) overwrite the streams in the DLP project.
i got the same two massages...
about the open GOP (what?) and the Compiler Error...
i'm so desperate!
anyway, here's the log - in case it can be useful...
when it gets to the last line it says "Aborted" in the Copmile section...Code:*** DVD Aa2 Pro Verification Log *** 3 - 31 - 2007 -- 20:5:56 ************************ * * * VMG Verification * * * ************************ Number of VTS - 1 Number of Menus: 1 Menu 01 - Type - Dummy Number of imported VTS: 0 ************************ * * * VTS Verification * * * ************************ <<< VTS Number 1 >>> Number of Titles: 20 Title 01 - Type - ES or PES Segment 1, Video File E:\Demuxed\dvd 2.m2v Frame Size: 720 X 576 Frame Rate 3 [1--23.976, 2--24, 4--29.97, 3--25, 5--30] Aspect Ratio: 43 [43--4:3, 169--16:9] MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2] Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4] GOP 1, size - 191208 GOP 2, size - 291400 GOP 3, size - 291944 Segment 1, Audio File E:\Demuxed\dvd 2.ac3 Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 256000 Segment 1, Subtitle File : None Title 02 - Type - Clone Title 03 - Type - Clone Title 04 - Type - Clone Title 05 - Type - Clone Title 06 - Type - Clone Title 07 - Type - Clone Title 08 - Type - Clone Title 09 - Type - Clone Title 10 - Type - Clone Title 11 - Type - Clone Title 12 - Type - Clone Title 13 - Type - Clone Title 14 - Type - Clone Title 15 - Type - Clone Title 16 - Type - Clone Title 17 - Type - Clone Title 18 - Type - Clone Title 19 - Type - Clone Title 20 - Type - Clone Number of Menus: 5 Menu 01 - Type - Dummy Menu 02 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\55321728_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\55321728_tmpsub1.bmp Picture size - 720 x 576 Menu 03 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\55949912_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\55949912_tmpsub1.bmp Picture size - 720 x 576 Menu 04 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\56054680_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\56054680_tmpsub1.bmp Picture size - 720 x 576 Menu 05 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\139911904_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\139911904_tmpsub1.bmp Picture size - 720 x 576 ************************ * * * Status Messages * * * ************************ Start building Video Title Set ( VTS ) ... - 2001 Title - 1 Start building VOB streams - 2210 Muxing elementary streams is in process ... - 2220 Initializing audio packets ... - 3005 Initializing AC3 (MOT) audio packet ... - 3030 [INFO] - No subtitle stream is provided - 3739 Muxing is in process ... - 2300 Audio packetizing ends - 3025 Creating PGC for the title is in process ... - 2500 Title - 2 Creating PGC for cloned title is in process ... - 2510 Title - 3 Creating PGC for cloned title is in process ... - 2510 Title - 4 Creating PGC for cloned title is in process ... - 2510 Title - 5 Creating PGC for cloned title is in process ... - 2510 Title - 6 Creating PGC for cloned title is in process ... - 2510 Title - 7 Creating PGC for cloned title is in process ... - 2510 Title - 8 Creating PGC for cloned title is in process ... - 2510 Title - 9 Creating PGC for cloned title is in process ... - 2510 Title - 10 Creating PGC for cloned title is in process ... - 2510 Title - 11 Creating PGC for cloned title is in process ... - 2510 Title - 12 Creating PGC for cloned title is in process ... - 2510 Title - 13 Creating PGC for cloned title is in process ... - 2510 Title - 14 Creating PGC for cloned title is in process ... - 2510 Title - 15 Creating PGC for cloned title is in process ... - 2510
and this annoying Compiler Error shown...
and! it always stucks in the same log line (case its important)...
thanks again... and sorry for the big bother...
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 19:39 -
a problem with result DVD after compiling with DVD-Lab
By soroush in forum Authoring (DVD)Replies: 4Last Post: 11th Dec 2007, 15:58 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 14:31 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 23:55 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 05:46
