Hello,
I'm using Canopus Procoder 2.04.02 for encoding video, BeLight 0.22RC1 for encoding audio to AC3 at 192Kbps, and DVD-lab PRO 2.30 for authoring the DVD (All softwares and files except procoder are latest versions). The video that I'm encoding is DV video (captured using firewire) of combined duration - 4hr26min32sec (combined using procoder during encoding). The encoding settings of canopus procoder are as in the pics: http://i2.tinypic.com/4y5l6d1.jpg http://i11.tinypic.com/6czuu7o.jpg.If i check 'Use strict GOP bitrate control' in the settings, the encoding stops halfway(maybe during the start of secon pass) and a message tell me that it failed to control GOP rate and to uncheck 'Use strict GOP bitrate control'. (I dont remember the exact msg, but its pretty close). This has happened all the times so i cant use that option
Now comes the main part, when i finish menu creating and all, and start the compiling process, the compiling stops automaticlly. Here is the log:
Please helpCode:*** DVD Lab Pro Verification Log *** 8 - 28 - 2007 -- 18:27:20 ************************ * * * VMG Verification * * * ************************ Number of VTS - 1 Number of Menus: 1 Menu 01 - Type - Dummy Number of imported VTS: 0 ************************ * * * VTS Verification * * * ************************ <<< VTS Number 1 >>> Number of Titles: 1 Title 01 - Type - ES or PES Segment 1, Video File C:\New Folder\{Stitched Source}_MPEG_3.m2v Frame Size: 720 X 576 Frame Rate 3 [1--23.976, 2--24, 4--29.97, 3--25, 5--30] Aspect Ratio: 43 [43--4:3, 169--16:9] MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2] Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4] GOP 1, size - 198622 GOP 2, size - 198961 GOP 3, size - 197217 Segment 1, Audio File F:\Part 1 Audio - LigH.ac3 Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 192000 Segment 1, Subtitle File F:\tm.sp1 Segment 1, Subtitle File C:\New Folder\Subs\tim.sp2 Segment 1, Subtitle File C:\New Folder\Comb.sp3 Number of Menus: 8 Menu 01 - Type - Dummy Menu 02 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\55607560_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\55607560_tmpsub1.bmp Picture size - 720 x 576 Menu 03 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\132660816_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\132660816_tmpsub1.bmp Picture size - 720 x 576 Menu 04 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\69665720_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\69665720_tmpsub1.bmp Picture size - 720 x 576 Menu 05 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\100423624_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\100423624_tmpsub1.bmp Picture size - 720 x 576 Menu 06 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\131483328_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\131483328_tmpsub1.bmp Picture size - 720 x 576 Menu 07 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\100219624_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\100219624_tmpsub1.bmp Picture size - 720 x 576 Menu 08 - Type - Still nMenu cell count - 1 Menu Image File C:\Temp\101320024_tmp1.bmp Picture size - 720 x 576 Menu Audio File - None Menu Sub-Picture File C:\Temp\101320024_tmpsub1.bmp Picture size - 720 x 576 ************************ * * * Status Messages * * * ************************ Start building Video Title Set ( VTS ) ... - 2001 Title - 1 Start building VOB streams - 2210 Muxing elementary streams is in process ... - 2220 Initializing audio packets ... - 3005 Initializing AC3 (MOT) audio packet ... - 3030 Muxing is in process ... - 2300 [ERR] GOP size is over the buffer limit - 2902 Authoring is terminated - 2999
The one thing that stands out to me is the Stream Format. You have yours set to Generic ISO Mpeg Stream. I always have mine set to DVD(Mpeg Program/Elementary Stream) and never have a problem with the output working in DLP. I rarely, if ever, need to go into the Advanced settings for DVD encoding.
Read my blog here.
Well......................,
The main reason why i didnt select the 'DVD(MPEG Program/Elementary Stream)' is because, it doesnt allow the bitrates which i want (It allows upto 2500kbps as opposed to the required 2000kbps). I'm dividing 9 DV cassettes into 2 DVDs. So i really want my bitrate to be 2000kbps.
Besides, i copied the exact same settings to my project(except the bitrate ofcourse).
P.S. whats DLP? -
DLP = DVD Lab Pro
2000 kbps is very low for Full-D1 video. The quality will be very poor unless the image is almost static.
I can't give you any other solution, except perhaps to use HCEnc as the encoder. It is very good at low bitrates.
Lord Smurf is a long time ProCoder user - perhaps he has seen this happen before.Read my blog here.
as gunslinger told you, you can't use Generic ISO Mpeg Stream setting to make a dvd compliant mpeg. it is for making mpeg transport streams only.
i should have added the only encoder i would even try to squish that video that much is cce. i'd give it a 7 or 9 pass vbr encode as that's probably the only why to keep it watchable with a bitrate that low.
I decided to encode the video at a higher bitrate and make 3 DVDs insted. So, i chose the 'DVD(MPEG Program/Elementary Stream)' and started the encoding. I will check if it works this time.
DVD Lab Pro Error: "Read data size is over the buffer limit"
By Motinha in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 02:49 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 18:39 -
video size quadruples in dvd lab pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 1Last Post: 13th Mar 2008, 19:23 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 13:31 -
DVD Lab Pro audio is out of sync after compiling
By GangstaRap in forum Authoring (DVD)Replies: 5Last Post: 8th May 2007, 04:46
