MSU cumulative update info (new free video tools & filters):
1. MSU Smart Deblocking filter 0.8 released.
http://compression.ru/video/deblocking/smartdeblocking_en.html
MSU Smart Deblocking 0.8 change log:
Improved block preprocessing algorithm
Improved main deblocking algorithm
The processing improves the PSNR quality metric of uncompressed and the processed videos
Speed and memory optimization, in comparison with the version 0.5:
• without preprocessing - up to 2.7 times faster
• with preprocessing - up to 2.4 times faster
Real-time processing of 2*CIF video
Simple user interface
Removed the "directional filtration" option
Fixed problem with yellow hue of the processed video
2. MSU Screen Capture Codec 1.2 released.
http://compression.ru/video/ls-codec/screen_capture_codec_en.html
16-bit video supported now
3. MSU Motion Estimation filter 0.5 released. (filter for effects for beginners and motion analysis for pro's)
http://compression.ru/video/motion_estimation/index_en.html
4. MSU Video Quality Measurement Tool 1.4 released.
http://compression.ru/video/quality_measure/video_measurement_tool_en.html
Bug fixing in BMP processing (visualization saving, etc)
5. MSU Cartoonizer 3.0 released
http://compression.ru/video/cartoonizer/index_en.html
New visualization - Filled Segments Rendering
Enjoy!![]()
With regards
Dmitriy Vatolin
http://www.compression.ru/video/ (News: new metrics and WMP vs JPEG-2000 comparison)
Senior editor of Compression-links.info -
DmitriyV (and msu team) a big THANK YOU, especially for the MSU Smart Deblocking filter!!!
Now, what I would like to see, is your de-interlace filter solution. Oh, and the improvements on that de-logo filter.
Thanks again! Smart Deblocking is a God saver!!! -
I am looking for older version of MSU Smart Deblocking filter v0.5. It had directional filtering support. Please let me know if you have it. Thank you!
@jagabo: thank you soooo much! I was really affraid it has been lost for good. This thing works so good for me.
New Free MSU Deinterlacer
By diablo23q in forum Video ConversionReplies: 1Last Post: 22nd Feb 2012, 09:55 -
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
MSU Deinterlacer Problems
By kernelhack in forum RestorationReplies: 3Last Post: 26th Sep 2008, 13:16 -
MSU FieldShiftFixer crashes
By greenbag in forum EditingReplies: 2Last Post: 7th Jan 2008, 21:22 -
MSU video filters cumulative announce
By DmitriyV in forum Latest Video NewsReplies: 4Last Post: 3rd Dec 2007, 05:45
