http://www.byremote.com.au/hip/
HIP is a Windows-based simple and highly configurable system that can allow you complete control of up to 81 different applications with a minimum of keys (all of which may be customised). Originally written to replace the software that was supplied to control the remote control of the Vision Plus DTV card, the system has grown to allow users a variety of interfaces which provides system control when a keyboard or mouse is not available particularly for Home Theatre PC (HTPC) users.
First HIP needs to receive a command. Many remote controls and keyboard use the Windows device called the Human Interface Parser which converts commands sent by Infrared into keyboard commands. HIP can process these pseudo-keystrokes, actual keystrokes or from other supported devices such as the Tira, USBUIRT, IRMan, ATI/X10 Remotes, HID devices (for much greater reliability) and even from the www.
When a key or command is received by HIP, the input is compared with a table of user-defined values and changed if necessary before sending it on to the application.
HIP offers the following features:
Quick and easy to configure and use
Automatically reassign keys for applications
Start applications if they are not running, or show them if they are
Optional On Screen Display, and other audio and visual alerts
Basic Audio Controls
2-Way Girder Interface
Optimised for HTPC configuration
Support a number of external IR units for the receiving and sending or IR Commands
Free for personal use
Pre-configured key commands for a variety of applications including: MCE, WinAmp, Media Player, Digitial Watch, Vision Plus, DigiVision, Zoomplayer, DigiTV, FusionTV and ShowShifter.
If you use the Enhanced HIP Master Control, the following additional features are available:
On-Screen Clock
Close/Switch to any running application
Run the Screen saver Shutdown your system
On-Screen Keyboard
Simple Mouse Movements
Help on Assigned Keys
System Scheduler (sends commands at predefined times)
Results 1 to 1 of 1
Remote control of computer?
By cwb in forum Media Center PC / MediaCentersReplies: 9Last Post: 29th May 2010, 18:29 -
Remote control WITH timer
By rdbierma in forum Newbie / General discussionsReplies: 0Last Post: 9th Mar 2010, 15:54 -
ATI remote control
By lazybum in forum Capturing and VCRReplies: 2Last Post: 12th Jun 2009, 17:19 -
Universal Remote Control
By titilucky in forum DVD & Blu-ray RecordersReplies: 11Last Post: 3rd Nov 2008, 14:31 -
remote desktop control
By pcb in forum ComputerReplies: 11Last Post: 9th May 2008, 06:00
